- Thank you received: 3
hal_manualtoolchange as signal for manual tool change button close to spindle
2 years 5 months ago #300570
by N3pu
Replied by N3pu on topic hal_manualtoolchange as signal for manual tool change button close to spindle
Now I have wired the button to an Input Pin and the ATC-Valve to an Output.
So I did the configuration now like this in .hal (atc_button is and2 instance):
when I now type "M6 T5" as MDI I can push my button and the ATC valve is acting.
BUT after changing the tool by hand Linuxcnc (gmocapy) still says T1 is inserted.
How is the procedure here to commit the change?
Are the nets "tool-change-confirmed" and "tool-number " needed somewhere? Or are they just in as a standard for user adjustment / routing?!
By the way: "I have no idea how it´s done usually - cnc newbie"
# ---Signale zum manuellen Werkzeugwechsel---
#net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
# ---Toolchange Button Integration during M6 Call---
addf atc_button servo-thread
net tool_change_request iocontrol.0.tool-change => atc_button.in0
net atc_button_on_spindle hm2_7i76e.0.7i76.0.0.input-29 => atc_button.in1
net atc_zylinder hm2_7i76e.0.7i76.0.0.output-04 <= atc_button.out
2 years 5 months ago - 2 years 5 months ago #300575
Replied by Aciera on topic hal_manualtoolchange as signal for manual tool change button close to spindle
Yes, I'd say you are lacking some feedback signals.
Try to add these to your hal:
net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared
net atc_zylinder iocontrol.0.tool-changed
[edit]
Note that the last line is probably not correct as you would really want a signal that reflects the tool change is complete. The usual manual toolchange has a popup window with an 'OK' button so the user can confirm that the toolchange has been completed.
[edit2]
Given the title of your topic I presume you are aware of this component but I do not know if you are actually using this along with your hardware button, which may be a good way to confirm tool change completion:
linuxcnc.org/docs/html/man/man1/hal_manualtoolchange.1.html
[edit]
[edit2]
Last edit: 2 years 5 months ago by Aciera.
2 years 5 months ago #300589
by N3pu
thanks for your help. i have now comment one more line to use the io tool-prepared.
when i now push the button after M6 Tx it justfires a small pulse to the atc_zylinder and then it shows the correct toolnumber in linuxcnc.
BUT the small pulse is to short to insert the tool / unclamp. I think that pushing the button fires the tool changed and then tool-change is not active anymore.
Maybe a way could be to watch the button rising and falling edge??
or could it makes more sense to tr the hal component "manualtoolchange" out?
#net tool-change-confirmed => iocontrol.0.tool-changed
# ---ignoriere Anfragen zu Werkzeug-Vorbereitungen---
#net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
2 years 5 months ago #300655
If you need a pulse on a falling edge have a look at the 'oneshot' component, which has a parameter setting for falling edge detection:
linuxcnc.org/docs/html/man/man9/oneshot.9.html
Time to create page: 0.178 seconds
