I get a PC with build-in parallel port. But i ran the parallel port tester and still got no response.
I can now toggle the machine power in linuxCNC. When I toggle it on, the machine can move when i toggle the machine power off it locks. But still no movement yet.
I have never seen anything like this. Have you tried to type a value? I don't use stepconf wizard very often.I’m at this stage noticing that I can’t change the velocity of y-axis (the one I’m testing). I think it might be the motor driver setting up problem.
