mechanical limits switches wiring for 7i96s MESA
03 May 2025 13:29 - 03 May 2025 14:33 #327598 by xlordofpainx
hey i am having some trouble wiring switches to the board here is what I tried:
I am using pnc conf
I read that the inputs are opticallyisolated so I can put a lot of voltage on the input pins (haven't tried yet only 5v)
the mechanical switchers have NC NO and C
I tried connecting NC to 5V and V to pin1 doesn't stop during homing
inverting just began the turn on with an error about the switch limit
I tried connecting NC to GND and V to pin1 doesn't stop during homing
I tried connecting NO to 5V and V to pin1 doesn't stop during homing
I tried connecting NO to GNFand V to pin1 doesn't stop during homing
FInally i tried attaching NC to 5V, NO to GND and C to pin one and it worked but then the mesa card would get restarted ( apparently its shorting something when i hold the button too long
i saw some other people connecting NC to 24V and then to pin 1, but it should work with 5V as well and it doesn't. i tried pin 0 as well in case the pin was not working.
i am getting the 5V and gnd from the STEP 3 pins.
I am very interested what exactly is it that I am doing wrong.
THanks
Last edit: 03 May 2025 14:33 by xlordofpainx.
03 May 2025 14:40 - 03 May 2025 14:48 #327601 by PCW
If you use NC limit switch contacts and sinking inputs, wiring would be:
7I96S input common (TB3 pin 12) = GND (24V common)
+24V --> Limit-Switch C --> Limit-Switch NC --> 7I96S Input (TB3 pin 1 through 11)
In hal, the input must be inverted.
You can use 5V instead of 24V but it's not as reliable long term with mechanical switches
Last edit: 03 May 2025 14:48 by PCW. Reason: clarify
03 May 2025 15:04 #327602 by xlordofpainx
Replied by xlordofpainx on topic mechanical limits switches wiring for 7i96s MESA
Thank you very much.
I don't understand how this is different from what I am trying. here is the setup:
Switch NC to 5V from one of the pins (would it be okay to plug it in the stepper motor DC 24 power supply?)
Switch C to PIN 1 TB3.
IN this case I am missing the TB3 common pin - will it work if I connect it to the GND from the MESA where I am getting the 5V will it work? It is not working as it is right now.
Eitherway if you say it is safe I will connect the DC power supply 24V to the limit switch NC then C switch to TB3 pin and I can connect the Common TB12 pin to the Power supply DC GND.
03 May 2025 15:33 #327603 by PCW
The isolated inputs will not work as expected unless you connect the
For sinking inputs (pullup to a positive voltage to activate), input common should be
connected to  GND/power common. If you are using 5V from the 7I96S, this is the
stepgen connector GND.
And yes if you use a 24V supply and sinking inputs, the 7I96S input common would
connect to the 24V supply common (negative)
The following user(s) said Thank You: xlordofpainx
03 May 2025 15:54 #327604 by xlordofpainx
THANKS!!! WORKS!
Now i understand, because they are isolated you need to connect the common pin to a GND reference point to the voltage that will be applied to the input 1-11 pins. I connected everything as you said and it works flawlessly. !!!!
This feels like a bigger achievement than getting my Master's degree haha.
Time to create page: 0.083 seconds
