New wifi card causes second parallel port to stop working
- sajurcaju
- Thank you received: 8
14 May 2025 12:42 #328441
by sajurcaju
New wifi card causes second parallel port to stop working was created by sajurcaju
Setup:
LinuxCNC 2.9.0 using Axis, configured with Stepconf
Dell Precision Workstation T3500, 8g ram
Radeon HD 5700
Two identical Sunix PCIe parallel port cards
Mint Debian Edition 6
#1 SMP PREEMPT_RT Debian 6.1.128-1 (2025-02-07)
6.1.0-31-rt-amd64
Why do I have two parallel port cards? Some time ago, I damaged the MB parallel port.
This setup works great.
When I add a wifi card (TP-Link PCIe Wifi card AC600), the second parallel port card address changes (per dmesg). I updated the hal with Stepconf for the new address. Now in Axis, the Machine Power button is grayed out, like the estop circuit is open. Estop-in is on the second parallel port card, so I'm interpreting this as the wifi card is somehow blocking the second parallel port card.
I shutdown, removed the wifi card, updated the second parallel port card address, and it all works fine again.
Put the wifi card back in and ran ptest
forum.linuxcnc.org/18-computer/4743-parallel-port-tester (thanks BigJohnT)
Both parallel port cards work with ptest, with the wifi card installed.
Advice will be greatly appreciated.
Steve
Radeon HD 5700
6.1.0-31-rt-amd64
Steve
- langdons
- Thank you received: 34
14 May 2025 14:14 #328451
by langdons
Replied by langdons on topic New wifi card causes second parallel port to stop working
Why do you need wi-fi?
Wi-Fi will increase latency for your CNC system.
Your CNC PC should be as minimal as possible.
Ethernet is far better than Wi-Fi anyhow.
- unknown
- Thank you received: 134
14 May 2025 14:24 #328453
by unknown
Replied by unknown on topic New wifi card causes second parallel port to stop working
Hard to really diagnose without seeing any relevant dmesg output or any info regarding the address of the parallel ports before failure and when failed.
If ptest works Linuxcnc should work.
- Thank you received: 6880
14 May 2025 14:27 #328454
Replied by tommylight on topic New wifi card causes second parallel port to stop working
In BIOS, see if there is the option to manually assign the IRQ resources and change the offending port IRQ so it is not the same as the WiFi card.
Not all PC's have that option.
- langdons
14 May 2025 14:27 #328455
by langdons
If you want to "surf the web", just get a second PC and use that for Wi-Fi.
Your CNC PC should probably be used solely for CNC stuff.
You can also potentially dual-boot (I recommend Ubuntu 22.04 LTS).
- langdons
14 May 2025 14:29 - 14 May 2025 14:30 #328456
by langdons
Some computers have a terrible BIOS with almost no features at all.
My Dell XPS 17 has like almost no helpful options in the BIOS.
It's incredibly lame.
Most PCs are UEFI nowadays anyways.
Last edit: 14 May 2025 14:30 by langdons. Reason: Added more info.
- unknown
14 May 2025 14:29 #328457
by unknown
Why do you do this, you add nothing, it's of completely no use.
Stop being an oxygen thief and find some other forum to ply your idiocy.
Does this stuff come naturally to you or do you have to work hard to be such a waste of space ?
My apologies to the OP but the user is a menace and I just couldn't put up with his complete uselessness.
- langdons
14 May 2025 14:35 #328460
by langdons
Please post the output of lspci -v
Did you try rearranging the cards?
Perhaps order matters.
Some computers are picky about such things.
Most computers I've seen have max 2 PCIe ports, you are fortunate to have 3, though perhaps this broken behavior explains why most PCs only have 2 ports.
- unknown
14 May 2025 14:42 #328462
by unknown
You can jam in as many parallel port cards as you have slots. They can be at any free address you have. If the on board one is buggered leaving it enabled will only affect the ISA compatible addresses, IE those hanging off the LPC bus. For the addresses allocated on the PCIe bus different realm, different interface, different bus. Hence the reason on board lpt ports don't show up via lspci, cos they are technically on the ISA bus but physically the LPC bus.
- langdons
14 May 2025 14:52 #328465
by langdons
lspci -v lists my installed Sunix parallel port PCIe card.
I also lists the haxadecimal port thingy (0xe30 or something).
To OP: You can buy a single card with 2 parallel ports from Sunix.
www.sunix.com/en/product_detail.php?pid=1434
