setting up 7i92 for directio on steppers
3 years 2 weeks ago - 3 years 2 weeks ago #282904 by dale fisher
the firmware I used with the 5i25 was flashed with pathpilot for mx3660 . I've got tormachs that run on pathpilot . And I had a non tormachs that ran pathpilot and was flashed the same and it was just a matter of modifying the configs . Another which is a novakon I used a bit file and configs from a post on cnczone .
I've been running my lathes with linuxcnc which works great . My compact 5 uses Sam's congigs which removed any need to modify my lathe . The other 2 are small retrofits which I want to get encoders working on . One is connected but the signals haven't been so great , threads sort of work but fail after numerous depth passes . As far as regular cutting they'll hold size all day long , it's just that the encoder signal isn't as consistent as it should be . As it stands I use ipm on those 2 which works but I should be using inch/rev
I understand that tormach has been using 7i92 lately , so I'm not opposed to crossing the 2 lathes over to pathpilot . I'm just unsure as to what tormach has been using for breakout boards
I've got 3 lathes total and the older one will remain linuxcnc and I prefer to keep them all the same if I can .
I searched around last night on how to modify the firmware but I'm still unsure how to go about it . I'm competent enough to figure out how to modify configs and stuff or figure things out as I go but I'm a bit lost when it comes to using and setting up the mesa cards . I know if I chip away at it I'll get it sooner or later , it's just a matter of finding the starting point
After rereading the previous posts , the mx4660 would work . I'm not married to the pinouts I have and swapping wires around is simple enough
Last edit: 3 years 2 weeks ago by dale fisher.
3 years 2 weeks ago #282907 by PCW
A MX4660 or MX3660 (3 axis only) pinout looks like an exact match to the stepconf pinout
3 years 2 weeks ago - 3 years 2 weeks ago #282910 by dale fisher
I've been flipping back and forth between linuxcnc and pathpilot in vmware . I see for lathe they have a 7i92t bit file and looking at the hal file it looks to be the same basic pinouts that I have .
Am I right in assuming that I can flash my cards with that bit file and set up linuxcnc from there
3 years 1 week ago #283831 by dale fisher
sometimes it's easier to connect everything and go through the motions rather than looking at other things from a distance . What started the confusion while looking at the hal for pathpilot is that it showed the pinouts . What I didn't notice was that there was a # on each line which means they likely put it there for their own benefit , and thats why the hal I created didn't show that
When looking at the pncconf wiz I hadn't realized that the selected stepgen of x for example gave predetermined pinouts for step and direction for the steppers . I've always been used to deciding on which pins I'd use for an axis , I suppose this is the same just different . It was just a matter of figuring out how to see the pinout for the stepgen and things became clear .
Anyhow , it'll be pretty straight forward for the next machine
