Mesa 7I92TM Parallel port pin mapping
2 years 2 months ago - 2 years 2 months ago #307938 by DougM
Successfully flashed 7i92t_5abobx2d.bin onto the MESA card (and performed a reload).
Here is the output of readhmid:
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 180.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 2 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 180.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort PWM 0 PWM (Out)
14 1 IOPort None
2 2 IOPort StepGen 0 Step/Table1 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir/Table2 (Out)
16 5 IOPort StepGen 8 Step/Table1 (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort StepGen 8 Dir/Table2 (Out)
5 8 IOPort StepGen 1 Dir/Table2 (Out)
6 9 IOPort StepGen 2 Step/Table1 (Out)
7 10 IOPort StepGen 2 Dir/Table2 (Out)
8 11 IOPort StepGen 3 Step/Table1 (Out)
9 12 IOPort StepGen 3 Dir/Table2 (Out)
10 13 IOPort None
11 14 IOPort QCount 0 Quad-A (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-IDX (In)
IO Connections for P1
1 17 IOPort PWM 1 PWM (Out)
14 18 IOPort None
2 19 IOPort StepGen 4 Step/Table1 (Out)
15 20 IOPort None
3 21 IOPort StepGen 4 Dir/Table2 (Out)
16 22 IOPort StepGen 9 Step/Table1 (Out)
4 23 IOPort StepGen 5 Step/Table1 (Out)
17 24 IOPort StepGen 9 Dir/Table2 (Out)
5 25 IOPort StepGen 5 Dir/Table2 (Out)
6 26 IOPort StepGen 6 Step/Table1 (Out)
7 27 IOPort StepGen 6 Dir/Table2 (Out)
8 28 IOPort StepGen 7 Step/Table1 (Out)
9 29 IOPort StepGen 7 Dir/Table2 (Out)
10 30 IOPort None
11 31 IOPort QCount 1 Quad-A (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-IDX (In)
and here is the current HAL file (after manual edits for num_encoders, num_stepgens and num_pwmgens)
# Generated by PNCconf at Fri Aug 16 08:59:19 2024
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=2 num_pwmgens=0 num_stepgens=3 sserial_port_0=00xxxxxx"
setp hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_7i92.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i92.0.write servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
setp hm2_7i92.0.stepgen.timer-number 1
# external output signals
# external input signals
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.000500
net x-index-enable => pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp hm2_7i92.0.stepgen.01.dirsetup [JOINT_0]DIRSETUP
setp hm2_7i92.0.stepgen.01.dirhold [JOINT_0]DIRHOLD
setp hm2_7i92.0.stepgen.01.steplen [JOINT_0]STEPLEN
setp hm2_7i92.0.stepgen.01.stepspace [JOINT_0]STEPSPACE
setp hm2_7i92.0.stepgen.01.position-scale [JOINT_0]STEP_SCALE
setp hm2_7i92.0.stepgen.01.step_type 0
setp hm2_7i92.0.stepgen.01.control-type 1
setp hm2_7i92.0.stepgen.01.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.01.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output => hm2_7i92.0.stepgen.01.velocity-cmd
net x-pos-fb <= hm2_7i92.0.stepgen.01.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_7i92.0.stepgen.01.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror 0.000500
net y-index-enable => pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp hm2_7i92.0.stepgen.00.dirsetup [JOINT_1]DIRSETUP
setp hm2_7i92.0.stepgen.00.dirhold [JOINT_1]DIRHOLD
setp hm2_7i92.0.stepgen.00.steplen [JOINT_1]STEPLEN
setp hm2_7i92.0.stepgen.00.stepspace [JOINT_1]STEPSPACE
setp hm2_7i92.0.stepgen.00.position-scale [JOINT_1]STEP_SCALE
setp hm2_7i92.0.stepgen.00.step_type 0
setp hm2_7i92.0.stepgen.00.control-type 1
setp hm2_7i92.0.stepgen.00.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.00.maxvel [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-vel-cmd <= joint.1.vel-cmd
net y-output => hm2_7i92.0.stepgen.00.velocity-cmd
net y-pos-fb <= hm2_7i92.0.stepgen.00.position-fb
net y-pos-fb => joint.1.motor-pos-fb
net y-enable <= joint.1.amp-enable-out
net y-enable => hm2_7i92.0.stepgen.00.enable
net y-home-sw => joint.1.home-sw-in
net y-neg-limit => joint.1.neg-lim-sw-in
net y-pos-limit => joint.1.pos-lim-sw-in
# AXIS Z JOINT 2
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.000500
net z-index-enable => pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp hm2_7i92.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP
setp hm2_7i92.0.stepgen.02.dirhold [JOINT_2]DIRHOLD
setp hm2_7i92.0.stepgen.02.steplen [JOINT_2]STEPLEN
setp hm2_7i92.0.stepgen.02.stepspace [JOINT_2]STEPSPACE
setp hm2_7i92.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE
setp hm2_7i92.0.stepgen.02.step_type 0
setp hm2_7i92.0.stepgen.02.control-type 1
setp hm2_7i92.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
net z-pos-cmd <= joint.2.motor-pos-cmd
net z-vel-cmd <= joint.2.vel-cmd
net z-output => hm2_7i92.0.stepgen.02.velocity-cmd
net z-pos-fb <= hm2_7i92.0.stepgen.02.position-fb
net z-pos-fb => joint.2.motor-pos-fb
net z-enable <= joint.2.amp-enable-out
net z-enable => hm2_7i92.0.stepgen.02.enable
net z-home-sw => joint.2.home-sw-in
net z-neg-limit => joint.2.neg-lim-sw-in
net z-pos-limit => joint.2.pos-lim-sw-in
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
# ---Use external manual tool change dialog---
net tool-change-request => hal_manualtoolchange.change
net tool-change-confirmed <= hal_manualtoolchange.changed
net tool-number => hal_manualtoolchange.number
# ---ignore tool prepare requests---
I still get no movement in any of the axes.  I wonder if there's something I am not properly enabling?  I didn't setup the Home or e-stop signals.
Thank you for your continued assistance,
Last edit: 2 years 2 months ago by DougM. Reason: add reload comment
2 years 2 months ago #307940 by PCW
Most common reason for lack of step/dir motion
is too short step lengths, So you might try doubling
those. Also check that the direction pin  to the step drive
changes state when jogging in either direction to verify
that the pinout is correct and that the  breakout board is
working as  expected.
2 years 2 months ago - 2 years 2 months ago #308316 by DougM
Can you tell me what the name of the factory firmware is (.bin)?
I want to start all over again.
Also, is there somewhere that explains the difference between a .bin, .bit and .pin files?
Thank you,
2 years 2 months ago #308322 by PCW
You just need to select firmware that matches your breakout.
The original firmware not really relevant, its just there to allow
access to the card for re-flashing to the desired firmware.
.pin files are just text file that list the included firmware modules
and the pinout of a specific firmware. These are created with
mesaflash and can be used to check firmware compatibility
with a given breakout.
.bit files are firmware files for Xilinx based FPGA cards
.bin files are firmware files for Efinix based FPGA cards
2 years 2 months ago - 2 years 2 months ago #308327 by DougM
Ah, so the .pin file is the descriptor for the .bin file. That's helpful :-)
I have 3 of these things and this is the first one I've ever flashed. Presumably the factory image has some standard pinout that miraculously matched the pin in's of the other two devices. That's what I want to get back to.
I put the thing on the scope and it's just not right. If I scope the original computer with native parallel i get a nice clean step signal, but if I scope this card I only get intermittent step pulses. But the width of the high pulse is the same as the native parallel.
So I want to get back to the native firmware just to see if the intermittent problem goes away. I think it will because when I first go this card it did work on a different machine.
Thanks for the explanation on the .pin and .bit files - that helped a lot.  Do I need to worry about Table1 and Table2 mapping?  Or is that all taken care of in PNCConf?
2 years 2 months ago #308331 by PCW
I suspect the default firmware is a 5ABOB type parallel port firmware
but I can check later.
Hunting on the step/dir outputs is more likely a setup issue than firmware
(since all firmware stepgens are identical)
