i changed the typo(error:), and not get error "no such file or dir"
i have the MyVCP.xml in the config folder /home/mill/emc2/configs/.
i'm guessing i need to find the folder it "should" be in.
[DISPLAY]
DISPLAY = axis
PYVCP = MyVCP.xml
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.8
# picture location /usr/share/emc/
INTRO_TIME = 3
PROGRAM_PREFIX = /home/mill/Gcode(Linux)
INCREMENTS = .1in .05in .01in .005in .001in .0005in 1in
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/mill/emc2/configs/Axis'
Machine configuration file is 'Axis.ini'
INIFILE=/home/mill/emc2/configs/Axis/Axis.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=14495
Killing task milltask, PID=14563
Cleanup done
Debug file information:
File "/usr/bin/axis", line 3942, in <module>
vcpparse.create_vcp(f, comp)
File "debian/tmp/usr/lib/python2.6/dist-packages/vcpparse.py", line 177, in create_vcp
File "debian/tmp/usr/lib/python2.6/dist-packages/vcpparse.py", line 47, in read_file
File "/usr/lib/python2.6/xml/dom/minidom.py", line 1918, in parse
return expatbuilder.parse(file)
File "/usr/lib/python2.6/xml/dom/expatbuilder.py", line 922, in parse
fp = open(file, 'rb')
IOError: [Errno 2] No such file or directory: 'MyVCP.xml'
14495
PID TTY STAT TIME COMMAND
14563
Stopping realtime threads
Unloading hal components
Kernel message information:
[10593.390864] I-pipe: Domain RTAI registered.
[10593.390869] RTAI[hal]:
.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[10593.390871] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[10593.390945] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[10593.390947] PIPELINE layers:
[10593.390949] fb64fe20 9ac15d93 RTAI 200
[10593.390951] c085cb20 0 Linux 100
[10593.406646] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[10593.407034] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[10593.407039] RTAI[sched]: hard timer type/freq = APIC/20833017(Hz); default timing: periodic; linear timed lists.
[10593.407042] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2500425000 hz.
[10593.407044] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[10593.407435] RTAI[usi]: enabled.
[10593.429748] RTAI[math]: loaded.
[10593.483326] config string '0x378 out '
[10594.382149] PnPBIOS: get_dev_node: function not supported on this system
[10594.382153] probe_parport 00:0a: disable failed
[10594.421835] RTAI[math]: unloaded.
[10594.436508] SCHED releases registered named ALIEN RTGLBH
[10594.497298] RTAI[malloc]: unloaded.
[10594.597033] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[10594.599616] I-pipe: Domain RTAI unregistered.
[10594.599711] RTAI[hal]: unmounted.
