Screen shots of gui designs
7 years 3 weeks ago #147651 by tommylight
7 years 3 weeks ago #147652 by tommylight
Nope, no go.
Missing /usr/share/qtvcp/screens/qtdragon
see attached
7 years 3 weeks ago #147653 by tommylight
7 years 3 weeks ago #147654 by persei8
Replied by persei8 on topic Screen shots of gui designs
qtvcp looks for the handler and ui files first in /usr/share/qtvcp and if not found, it looks in the config dir that it was launched from. This message always comes up unless you actually install to /usr/share (which is not necessary) It looks like it wants python-opencv to be installed. I have never seen the second 2 errors before so they may be related to opencv not being installed. I would also do an update to make sure you have the latest qtvcp libraries.
7 years 3 weeks ago #147655 by cmorley
Replied by cmorley on topic Screen shots of gui designs
It's not finding the preference file. It's a bug as it should make the preference file if not found.
qtdragon is available in linuxcnc version 2.8 + and it should start up (I redirected the preference file to the standard user directory)
Chris M
7 years 3 weeks ago - 7 years 3 weeks ago #147656 by persei8
Also I just noticed that I have an absolute path in the ini file for PROGRAM_PREFIX. You will need to edit that to suit your own path or replace it with ../nc_files or whatever yours is called. I also just added the preference file to github.
Last edit: 7 years 3 weeks ago by persei8. Reason: Added preference file
Time to create page: 0.239 seconds
