need help on setup of qtvcp
7 years 5 months ago #134957 by Reinhard
you may have to add the python folder.
Hm, I tested to link the plugins directory into designer directory, but then designer crashed before installing svg lib.
What distribution are you using?
I use debian stable (stretch or 9.9) on my desktop (kde) with daily updates and I have a fresh installation in a virtual box with debian stretch and linuxcnc
I have no idea of python and its requirements, so I need your help.
7 years 5 months ago #134958 by Reinhard
I added python3-pyqt5.qtsvg and it didn't hurt anything.
That library did not hurt my system either. I had that installed before.
python-pyqt5.qtsvg was the killer. I guess thats the library for python2, which is used by screen-infrastructure
7 years 5 months ago #134959 by cmorley
Replied by cmorley on topic need help on setup of qtvcp
The link to qtvcp_plugin.py must go in /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python
7 years 5 months ago #134960 by Reinhard
I removed that svg library (apt purge python-pyqt5.qtsvg) and designer is able to start again. But without linuxcnc ...
7 years 5 months ago #134961 by Reinhard
There it is:
:/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python# ll insgesamt 4 lrwxrwxrwx 1 root root 62 Mai 26 05:34 qtvcp_plugin.py -> /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py
7 years 5 months ago #134962 by cmorley
when you start designer now clck 'helpt' select 'about plugins' and see if it found the library libpyqt5_py2.so
Time to create page: 0.345 seconds
