GScreen limit switch issue
4 years 8 months ago #234437 by Ivan_The_Red
I tried to locate the EMC_Interface.py file in those directories and they dont exist on my machine......any suggestions? below is a picture of what i have in my /usr/lib/python2.7/dist-packages directory.
4 years 8 months ago #234447 by cmorley
Replied by cmorley on topic GScreen limit switch issue
can you try this; open a terminal and run:
locate emc_interface.py
4 years 8 months ago #234450 by Ivan_The_Red
well, looks like i hit the jackpot.....which one should i replace?
4 years 8 months ago #234451 by cmorley
gscreen/emc_interface.py
please keep a copy of the original so you can go back if there is a problem.
You will need to be sudo to modify the files.
(There are other ways to do this but this is one way, use what is familiar to you)
in a terminal
sudo thunar
(depends on what system you are using, hopefully you have thunar)
should get you a sudo file manager
Using the sudo file manager, I would temporarily rename the original file then copy in the new file.
then kill the sudo file manager so you don't do any accidental damage.
Then try linuxcnc and see if i did any good :)
4 years 8 months ago #234453 by Ivan_The_Red
i did try using 'find' and 'grep' to try and locate that file and had no luck.....but i searched for EMC_Interface.py maybe the capitol letters balled that attempt up. im confident ill be able to get that accomplished and ill get back with you tomorrow after i get home from work.
Thanks again, i do appreciate it.
4 years 8 months ago #234454 by cmorley
ya files are case sensitive in linux.
All good -thanks for trying to test the changes!
Time to create page: 0.280 seconds
