- Thank you received: 2181
What version of linuxcnc does this not work?mjohnsonsa wrote: Does the latest version address the issue with pncconf not letting you proceed with the wizard when you select a tandem access? It ask you to select which stepper is master but does not appear to give you a method to do so...
