when I check this in glade I get the version 3.12.1. But as stated in the manual I call glade-gtk2 to change the UI. There the version is 3.8.0. But I'm doubting that this has something to do with glade itself but more with matplotlib.
How should I update the glade to test it?
@Andy: I'm trying to figure out if vismach is an alternative. I did the test in the toolchanger example as stated above. This was working fine. But when I try this in the puma560 simulation my stl-file is not comming up. I copied the puma560gui.py into the folder, changed the call in the .hal file. When I simply add the .stl file nothing is dispalyed. When I change the link1 (original file link1.obj with torso.stl) by:
link1 = AsciiSTL(filename="torso.stl");
#link1 = AsciiOBJ(filename="puma_link1.obj");
link1 = Color([0.18,0.19,0.2,1],[link1])
link1 = Rotate([link1], 180,0,0,1)
There is simply the link1 missing in vismach but not exchanged with torso.stl.
I checked link1.obj and torso.stl in meshlab (dimensions, position, ...) so it is simply not hidden somewhere. All that looks good (torso is 2 times bigger).
In the toolchanger example the .stl-File is correctly displayed in the model. What is different with the puma560gui.py? The code is used (otherwise the link1.obj would not be missing in the vismach display)??
My goal at the end is to have the additional .stl displayed in the view together with the robot simulation. This would be great.
Many thanks again.
