Newbie needs startup help!!!
06 Sep 2012 17:56 #23985
by thos913
Newbie needs startup help!!! was created by thos913
I am a complete newbie to linux. I was running my homebuilt 48 x 48 cnc router on windoze but had problems with it dropping steps. I spoke to a programmer friend and he suggested Linuxcnc. I formatted the machine and loaded linux 2.5.1 and linuxcnc. Immediately on startup the machine froze as it tried to open axis. I could not find a reason for this but was able to change to the mini gui and it works like a champ. I have configured the machine and it runs fine using the mini gui. I have read that axis has a tool touchoff utility but I see no mention of it with other gui packages. Is it possible to use the touchoff with other guis or should I be able to fix axis. I am running a Dell GX240 it has 512 meg of memory. it says it has an agp video setup and has a P4 processor running at 1.8 ghz. As earlier stated I an a Linux newbie and dont understand a lot of this. Any help would be appreciated. Please keep it as simple as possible
K Norman
K Norman
06 Sep 2012 21:31 #23990
Replied by andypugh on topic Re:Newbie needs startup help!!!
thos913 wrote:
That is almost certainly a graphics card or open-gl problem.
Try these suggestions:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oting#Display_Issues
07 Sep 2012 10:25 #24007
by Rick G
Replied by Rick G on topic Re:Newbie needs startup help!!!
Have you tried both 8.04 and 10.04 from the live cds?
Rick G
Rick G
16 Sep 2012 23:34 #24317
by thos913
Replied by thos913 on topic Re:Newbie needs startup help!!!
I got the problem with the axis GUI fixed. It was a video driver. Now I am still trying to figure out the tool touch off. I cant seem to figure out the tool touchoff setup. Any help would be appreciated.
K Norman
K Norman
16 Sep 2012 23:38 #24318
What part of it isn't behaving like you expect, and what do you expect?
17 Sep 2012 11:26 - 17 Sep 2012 11:31 #24328
by Rick G
Have you looked here...
gnipsel.com/linuxcnc/g-code/gen01.html
and
wiki.linuxcnc.org/cgi-bin/wiki.pl?CoordinateSystems
Rick G
and
Rick G
Last edit: 17 Sep 2012 11:31 by Rick G.
Time to create page: 0.105 seconds
