My Steppers won‘t work
3 years 7 months ago #267230 by tommylight
3 years 7 months ago #267231 by Elias B.
Replied by Elias B. on topic My Steppers won‘t work
This is the Output, looks correct
Configuration Name: HOSTMOT2 General configuration information:   BoardName : MESA5I25   FPGA Size: 9 KGates   FPGA Pins: 144   Number of IO Ports: 2   Width of one I/O port: 17   Clock Low frequency: 33.3333 MHz   Clock High frequency: 200.0000 MHz   IDROM Type: 3   Instance Stride 0: 4   Instance Stride 1: 64   Register Stride 0: 256   Register Stride 1: 256 Modules in configuration:   Module: WatchDog   There are 1 of WatchDog in configuration   Version: 0   Registers: 3   BaseAddress: 0C00   ClockFrequency: 33.333 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: IOPort   There are 2 of IOPort in configuration   Version: 0   Registers: 5   BaseAddress: 1000   ClockFrequency: 33.333 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: QCount   There are 2 of QCount in configuration   Version: 2   Registers: 5   BaseAddress: 3000   ClockFrequency: 33.333 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: SSerial   There are 1 of SSerial in configuration   Version: 0   Registers: 6   BaseAddress: 5B00   ClockFrequency: 33.333 MHz   Register Stride: 256 bytes   Instance Stride: 64 bytes   Module: StepGen   There are 10 of StepGen in configuration   Version: 2   Registers: 10   BaseAddress: 2000   ClockFrequency: 33.333 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: LED   There are 1 of LED in configuration   Version: 0   Registers: 1   BaseAddress: 0200   ClockFrequency: 33.333 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes Configuration pin-out: IO Connections for P3 DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir  1                      0   IOPort       StepGen          5        Dir/Table2      (Out) 14                      1   IOPort       StepGen          5        Step/Table1     (Out)  2                      2   IOPort       StepGen          6        Dir/Table2      (Out) 15                      3   IOPort       StepGen          6        Step/Table1     (Out)  3                      4   IOPort       StepGen          7        Dir/Table2      (Out) 16                      5   IOPort       StepGen          7        Step/Table1     (Out)  4                      6   IOPort       StepGen          8        Dir/Table2      (Out) 17                      7   IOPort       StepGen          8        Step/Table1     (Out)  5                      8   IOPort       StepGen          9        Dir/Table2      (Out)  6                      9   IOPort       StepGen          9        Step/Table1     (Out)  7                     10   IOPort       SSerial          0        TXData2         (Out)  8                     11   IOPort       SSerial          0        RXData2         (In)  9                     12   IOPort       SSerial          0        TXData3         (Out) 10                     13   IOPort       SSerial          0        RXData3         (In) 11                     14   IOPort       QCount           1        Quad-IDX        (In) 12                     15   IOPort       QCount           1        Quad-B          (In) 13                     16   IOPort       QCount           1        Quad-A          (In) IO Connections for P2 DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir  1                     17   IOPort       StepGen          0        Dir/Table2      (Out) 14                     18   IOPort       StepGen          0        Step/Table1     (Out)  2                     19   IOPort       StepGen          1        Dir/Table2      (Out) 15                     20   IOPort       StepGen          1        Step/Table1     (Out)  3                     21   IOPort       StepGen          2        Dir/Table2      (Out) 16                     22   IOPort       StepGen          2        Step/Table1     (Out)  4                     23   IOPort       StepGen          3        Dir/Table2      (Out) 17                     24   IOPort       StepGen          3        Step/Table1     (Out)  5                     25   IOPort       StepGen          4        Dir/Table2      (Out)  6                     26   IOPort       StepGen          4        Step/Table1     (Out)  7                     27   IOPort       SSerial          0        TXData0         (Out)  8                     28   IOPort       SSerial          0        RXData0         (In)  9                     29   IOPort       SSerial          0        TXData1         (Out) 10                     30   IOPort       SSerial          0        RXData1         (In) 11                     31   IOPort       QCount           0        Quad-IDX        (In) 12                     32   IOPort       QCount           0        Quad-B          (In) 13                     33   IOPort       QCount           0        Quad-A          (In)
3 years 7 months ago #267235 by tommylight
Replied by tommylight on topic My Steppers won‘t work
Seems like it does need firmware for 7i76 to be flashed.
Go to Mesa 5i25 page, there should be firmware for download there, where the PDF manual is.
Find a how to flash Mesa, use the bin file with 5i25 and 7i76 in the name.
Sorry for not helping much, on the phone.
The following user(s) said Thank You: Elias B.
3 years 7 months ago #267238 by PCW
Replied by PCW on topic My Steppers won‘t work
If you measure the DIR0+ output to ground, with a voltmeter
does it change when you jog X in both directions?
3 years 7 months ago - 3 years 7 months ago #267242 by Elias B.
It works now. Thank you all so much.
The firmware as the problem
Last edit: 3 years 7 months ago by Elias B..
Time to create page: 0.072 seconds
