Update Ubuntu 8.04 to 8.10 or 9.04
06 May 2009 20:46 #217
by TRibor
Update Ubuntu 8.04 to 8.10 or 9.04 was created by TRibor
Hello,
I'm use the EMC2 in Ubuntu 8.04.
If I update the Ubuntu 8.04 to 8.10 or 9.04 the EMC2 will run after, Or only run in the 8.04?
Regards,
Tibi
Regards,
Tibi
- skunkworks
- Thank you received: 148
06 May 2009 21:25 #218
by skunkworks
Replied by skunkworks on topic Re:Update Ubuntu 8.04 to 8.10 or 9.04
The precompiled versions of emc2 are only compatible with Ubuntu 6.06 and Ubuntu 8.04. Upgrading to 8.10 will remove the emc packages and make your system unable to run emc.
- fp5757
- Visitor
12 Jul 2009 02:59 #521
by fp5757
Replied by fp5757 on topic Re:Update Ubuntu 8.04 to 8.10 or 9.04
Forget the binary versions of emc2, what if I down load the sources of EMC2 on 9.04 and recompile EMC2 will it work on 9.04? Anyone feel free, thanks in advance.
12 Jul 2009 17:19 #524
by Edge
Replied by Edge on topic Re:Update Ubuntu 8.04 to 8.10 or 9.04
Or even just 8.04.2. I can't get Ubuntu installed on anything but that or above! Help!
- SherlineMike
29 Jul 2009 21:18 #650
by SherlineMike
Replied by SherlineMike on topic Re:Update Ubuntu 8.04 to 8.10 or 9.04
I would say that no it won't work unless you have the RTAI kernel package
30 Jul 2009 06:23 #652
by alex_joni
Replied by alex_joni on topic Re:Update Ubuntu 8.04 to 8.10 or 9.04
fp5757 wrote:
Sure, that will work.
But you need to rebuild the kernel on any linux version you're picking.
We need a rtai patched kernel (www.rtai.org), to be able to compile and run emc2.
So if you start with 9.04, you need to grab the sources from the kernel used in 9.04 (I think 2.6.29 or 30), then patch them according to the instructions from rtai, build a working kernel (usually after 2-3 attempts), and afterwards compile rtai, then grab the emc2 sources and compile/run them.
There are some instructions how to do this in the wiki at wiki.linuxcnc.org, however some might be older (out of date).
Regards,
Alex
Regards,
Alex
16 Nov 2009 03:04 #1135
by Rustam
Replied by Rustam on topic Re:Update Ubuntu 8.04 to 8.10 or 9.04
How to get to work emc2 on kubuntu 9.4,9.10?
24 Nov 2009 06:00 #1180
by Bari
Replied by Bari on topic Re:Update Ubuntu 8.04 to 8.10 or 9.04
If you wish to build and install EMC2 yourself in Ubuntu 9.04 or 9.10 including the RTAI kernel patches, here's a HOWTO:
neo-technical.wikispaces.com/emc2-ubuntu
Time to create page: 0.608 seconds
