latency test question
15 Jan 2013 08:37 - 15 Jan 2013 11:24 #28710
by revo
Replied by revo on topic latency test question
update,
i plugged the computer on the machine, ran the serup wizard and put all the pin where they are supposed to be for my board, running gecko 201. ran my latency test for hrs and ended up at 6000 which seem to be good.
next setp was to test the axis and i get no movement from any of them, anyway i put all my limits and everything else on the wizard and the address of the parallel port is right.
when open linux cnc and get some movement on the X but not on the other axis and the movement is so small. mini step at the time, just to jog 10'' take forever even with the jog speed to the max.
my setup is xyza, the A is the same as the x. is there a way to slave the axis on linux cnc? its a huge 13 feet long x 4 feet cnc so the x has 2 motors.
i am having a hard time to get this going, weird because on mach3 the machine just purr...
Last edit: 15 Jan 2013 11:24 by revo.
15 Jan 2013 17:15 #28713
by ArcEye
Replied by ArcEye on topic latency test question
Glad your latency is sorted out
This is a completely different question(s), which no-one can help with because we don't have a clue what your configuration is.
Suggest you re-post under the Basic Configuration section, with copies of your .ini and .hal files
11 Feb 2013 12:59 #29891
by revo
sorry for noob question but how do i post hal and ini files?
11 Feb 2013 17:32 #29897
by ArcEye
Easiest way is to copy the contents of /home/yourname/linuxcnc/configs/yourconfigname into a .zip file and attach to a post using 'Add File' at the bottom of the posting form.
See /usr/share/doc/linuxcnc/examples/sample-configs/gantry for example set up
Run man gantrykins in a terminal for info on how the module works
11 Feb 2013 19:28 #29899
by Rick G
If you do not need to home the slave axis separately,( do not have separate home/ limit switches on A and X) you can just slave them together in your hal file as X.
If this is the case lets us know as there are several ways to connect them and probably simpler than use gantry config.
Rick G
Replied by Rick G on topic latency test question
Rick G
Time to create page: 0.311 seconds
