- Thank you received: 75
Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- cncnoob1979
- Topic Author
9 years 7 months ago #89373
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
PKM:
Those two are just some of the items installed from 3rd party. Its up to you if you want to install it. I do, and I remove those two items I had mentioned because of the build time warnings. I will edit as discussed to help those out later on to save confusion.
My advise is to read and re-read the posting to understand the sequence. Once you do check out post 4. As far as steps go... it not difficult.
This guide is bare minimum directions to install [so many different possibilities], my real chore is to explain the []why and []when. I have spent an awful amount of time to test each sequence and step via trial and error.
cut2cut:
Actually IMHO, a noob will more than likely try a RIP to test out new branches later on. Have you tried master yet? I really like the master branch so I can keep up to date with changes, so far I have not had a broken git pull. A rip is very easy to manage and use... once you have one and tried it a few times.
How is your install going btw? Are you configured/running yet?
A .deb install is locking you into a version, without updates ect.. if you are just trying things to see what you like.. a rip is the way to go.
But for someone who doesn't fancy new things and just want an install and go... You really do want a .deb install
cut2cut:
9 years 7 months ago #89375
by cut2cut
Replied by cut2cut on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Hey James,
The software part has been working great thanks to you and the others on this thread like Tommy and Rod. Looking back it was a great experience but only because it ended well ! lol. Since then, I have had some minor teething issues understanding how to use PNCconf for my Mesa 7i76e controller card but that didn't take long. I have all three axis working and the spindle too which is great ! Getting the VFD (spindle motor ) to work with the 7i76e was a wee bit over my head ( actually a lot ) but thankfully my brother was able to create a wiring diagram. He's an electrical engineer. The Mesa controller board is quite good engineering I'm told by those that helped me, however the manual is not very "noob" friendly. Not complaining, just from my perspective, they aren't targeting the noobhobbyist for their product
Hope you are well !
P.s. Maybe I'm mistaken but the RIP build doesn't create short cuts to the manuals, step config, PNCconf, etc... right ? Anyway, I just like things to work first, then experiment. I believe I have version 2.7.8 of linuxcnc but I'd have to double check that number !
Jake
Jake
- cncnoob1979
- Topic Author
9 years 7 months ago - 9 years 7 months ago #89376
by cncnoob1979
Hey Jake!
Glad your starting to get up and going. Yeah manuals can be a bear to wrap your head on. My head too!
Once you understand what your looking for, the manual becomes painfully clear
I really enjoy Mesa products.
The rip will install the shortcuts in the main menu. You just have to uncheck/recheck them like with the deb. The rip becomes a pain when you want to install Glade to edit panel or if trying to install NCam or Work with probe. These are looking for standard LinuxCNC installation locations and can be frustrating to install with your RIP configuration.
Last edit: 9 years 7 months ago by cncnoob1979.
9 years 7 months ago #89428
by steveg
Replied by steveg on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Hi James ,after adding the amd64 repo everything worked flawlessly.
Steve
Steve
- cncnoob1979
- Topic Author
9 years 7 months ago #89466
by cncnoob1979
Thanks for the Feedback Steve! Glad it worked out for you.
9 years 7 months ago #89683
by fjr122
Replied by fjr122 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Hello,
I'm new here.
Cncnoob thanks for making this guide.
Debian was going to be alot of trouble as it did not recognize my wifi card. In my opinion Mint is far superior.
I've been trying to follow this guide with two little hangups..
First When I try to get the keys..
I solved this by changing keyservers and that actually worked..
Then a few steps later, I run into the following:
Any ideas on this one?
I'm new here.
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
[sudo] password for linuxcnc:
Sorry, try again.
Executing: /tmp/tmp.mMhoMpQaIr/gpg.1.sh --keyserver
--recv-key
3cb9fd148f374fef
gpg: requesting key 8F374FEF from hkp server keys.gnupg.net
gpg: keyserver timed out
gpg: keyserver receive failed: keyserver error
sudo apt-key adv --keyserver hkp://pgp.mit.edu --recv-key 3cb9fd148f374fef
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linux-headers-3.4-9-rtai-686-pae:i386 : Depends: gcc-4.6:i386 but it is not installable
E: Unable to correct problems, you have held broken packages.
Time to create page: 0.137 seconds
