- Thank you received: 75
Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- cncnoob1979
- Topic Author
9 years 7 months ago #89696
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
I assume you are using post 3?
Did you try a sudo apt-get update after adding the repo?
9 years 7 months ago #89698
by fjr122
Replied by fjr122 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Yes Post 3
"POST 3 = Installing pre-compiled RTAI Kernel from apt using .debs"
And I have followed the instructions exactly so I did do the update..
(ok except I left the 3rd party stuff in)
Fresh clean install of Mint, the only thing I've done is change the screensaver/power settings and changed the search engine to Google.
(I was hoping you would infer post 3 from what I sent, but I know that computer guys like to stay away from assumptions, and linux guys in particular)
9 years 7 months ago #89703
Replied by tommylight on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Fjr122
Did you enable the source code in synaptics?
I am sure i got that error when i forgot to check that.
9 years 7 months ago #89707
by fjr122
Tommylight,
I followed the instructions exactly.
So yes I did.
So yes I did.
9 years 7 months ago #89710
Also removed the ndiswrapper and virtualbox?
It was a month ago so i can not recal the exact order of events, but i remember doing these two steps, update, and it installed properly.
- cncnoob1979
- Topic Author
9 years 7 months ago - 9 years 7 months ago #89712
by cncnoob1979
Add this repo
Then
Just tested this and it works for me. I had the repo enabled prior so I did not have an issue as many others may have had already. When I get time ill update the HOW-TO.
Sorry for any inconvenience.
James
EDIT: Once completed I would uncheck this repo since it is precise base. No need to cross-contaminate Xenial with it
sudo add-apt-repository 'deb http://mirrors.kernel.org/ubuntu precise main'
Then
sudo apt-get update
sudo apt-get install gcc-4.6
sudo apt-get install linux-headers-3.4-9-rtai-686-pae rtai-modules-3.4-9-rtai-686-pae linux-image-3.4-9-rtai-686-pae
James
Last edit: 9 years 7 months ago by cncnoob1979.
Time to create page: 0.072 seconds
