i don't have connection
4 years 6 months ago #241701 by isaac85
Replied by isaac85 on topic i don't have connection
i tried all this ip for address
but nop, not work
i tried install a usual debian in the same computer and it is giving to me the same problem.
so i am thinking use ubuntu or arch.
i will try install preempt-rt and linuxcnc there.
some suggest, advice or tip?
4 years 6 months ago - 4 years 6 months ago #241706 by rodw
Replied by rodw on topic i don't have connection
My guess is drivers required for your network interface do not exist in Debian Buster.
Tell us about your PC make, model, network interface if known
I would recommend you try to  install debian testing (bookworm) from this download
cdimage.debian.org/cdimage/unofficial/no...builds/amd64/iso-cd/
once installed (assuming the network driver is found) type these lines:
sudo apt update
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash
linuxcnc
Last edit: 4 years 6 months ago by rodw.
The following user(s) said Thank You: isaac85
4 years 6 months ago #241731 by isaac85
Motherboard Biostar racing z490 gtn mini itx
socket 1200 with intel pentium gold cpu
lan Intel i219V
wifi intel wirless 9560
gpu radeon rx 550
i will try what you say.
but for the moment i installed arch with a kernel real time and linuxcnc work there.
i am new in linuxcnc and i must learn how work all the configs and hal...
do you think will be difficult make work 7i95 with arch?
Time to create page: 0.051 seconds
