Running LinuxCNC on a Raspbery Pi5 using the Byte2Bot daughter board
8 months 4 weeks ago #342339 by EdWorks
My system is running beautifully. My goal is to make "Running LinuxCNC on a Raspbery Pi5 using the Byte2Bot daughter board" simpler, more successful with fewer "Gotchas" than other options.
8 months 4 days ago #343664 by magpie_lark
I'm trying to set up the DB25 board to connect to a geckodrive G540 and running into some confusion. Currently reading the byte2bot guide on this and I'm confused about the hal_gpio pin naming. Where are these pin numbers for "pi5 2025" coming from?  They don't seem to match any pin mapping I've seen in any other online source. Do I use the 2023 or 2025 one?
Image of pinout naming matrix below.
Time to create page: 0.612 seconds
