2.4. Building emc2 (realtime)
- garymcrobertpdx
09 Jan 2011 01:05 #6561
by garymcrobertpdx
2.4. Building emc2 (realtime) was created by garymcrobertpdx
I have installed emc2 via the live disk and it works well.
Now my goal is to modify the interp_convert.cc file and incorporate in EMC2
the question is how do I proceed. I have used git to down load and create
the emc2-dev directories. I have studied the doc Installing EMC2 particularly
section 2.4. Building emc2 (realtime) .
the sentence "If you have already installed EMC from the Live CD do not use --
prefix/make install. Use the 'run in place' method (the default) instead. "
What is meant by 'run in place' ?
Run these commands in the directory created by git above (usually emc2-dev):
$ cd src
$ ./autogen.sh
$ ./configure
$ make
$ make install-menus
$ sudo make setuid
some experimenting with this sequence of commands produces only error messages.
me@CNC:~/emc2-dev/src$ cd ..
me@CNC:~/emc2-dev$ cd src
me@CNC:~/emc2-dev/src$ ./autogen.sh
./autogen.sh: line 6: autoconf: command not found
me@CNC:~/emc2-dev/src$ ./configure
bash: ./configure: No such file or directory
me@CNC:~/emc2-dev/src$ make
Makefile:55: Makefile.inc: No such file or directory
Makefile:66: *** Makefile.inc must specify RTPREFIX and other variables. Stop.
Again a guiding hand would be appcated, thanks
$ cd src
$ ./autogen.sh
$ ./configure
$ make
$ sudo make setuid
09 Jan 2011 09:03 #6562
by alex_joni
Replied by alex_joni on topic Re:2.4. Building emc2 (realtime)
sudo apt-get build-dep emc2
You are missing some dependencies needed for compiling emc2
09 Jan 2011 13:17 #6568
by BigJohnT
Replied by BigJohnT on topic Re:2.4. Building emc2 (realtime)
You skipped a step if your following the wiki instructions.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ge_already_installed
RIP, run in place is when you run EMC2 from the directory created by git.
Follow this when you want to run the RIP
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ng_EMC2#Running_emc2
I create a desktop launcher to build EMC when I'm putzing around with it to save all the typing. Pick launch in a terminal and you can see the errors when you make one.
- garymcrobertpdx
10 Jan 2011 21:25 #6605
by garymcrobertpdx
Replied by garymcrobertpdx on topic Re:2.4. Building emc2 (realtime)
Thanks that helped a lot. I think emc2-dev is configured now.
So I did the 2.4. Building emc2 (realtime)
$ cd src
$ ./autogen.sh
$ ./configure
Masses of text scrolled down the terminal window concluding with a
message declaring success.
# It seems that ./configure completed successfully. #
# This means that RT is properly installed #
# If things don't work check config.log for errors & warnings #
# Next compile by typing #
# make #
# sudo make setuid #
# Before running the software, set the emc environment: #
# . (top dir)/scripts/emc-environment #
# To run the software type #
# emc
Looks good so far. Do I set set the emc environment before using make or after
and how do i do this?
$ cd src
$ ./autogen.sh
$ ./configure
# make #
# emc
11 Jan 2011 00:47 - 11 Jan 2011 00:47 #6607
by BigJohnT
Yea it is like this for dev...
cd src
./autogen.sh
./configure
make
sudo make setuid
. ./emc-environment
emc /home/path/to/your/config/myconfig.ini
You can navigate to your your config directory and do a pwd to find the fully qualified path.
I love it when a plan comes together...
cd src
./autogen.sh
./configure
make
sudo make setuid
. ./emc-environment
Last edit: 11 Jan 2011 00:47 by BigJohnT.
- garymcrobertpdx
12 Jan 2011 01:59 #6637
by garymcrobertpdx
When I ran make, near half way through I see about two dozen warnings like this
Building modules, stage 2.
MODPOST 126 modules
make[1]: Leaving directory `/usr/src/linux-headers-2.6.24-16-rtai'
WARNING: "fabs" [/home/me/emc2-dev/src/steptest.ko] undefined!
WARNING: "rt_task_wait_period" [/home/me/emc2-dev/src/rtapi.ko] undefined!
WARNING: "rt_sem_wait" [/home/me/emc2-dev/src/rtapi.ko] undefined!
WARNING: "frexp" [/home/me/emc2-dev/src/rtapi.ko] undefined!
WARNING: "rt_sem_delete" [/home/me/emc2-dev/src/rtapi.ko] undefined!
WARNING: "rt_task_init_cpuid" [/home/me/emc2-dev/src/rtapi.ko] undefined!
Is this trouble or do I ignore them?
thanks
MODPOST 126 modules
thanks
12 Jan 2011 12:34 #6644
by BigJohnT
Just ignore warnings...
- garymcrobertpdx
12 Jan 2011 19:10 #6654
by garymcrobertpdx
Getting closer to getting it together but still not working correctly.
when I typed EMC while in the emc2-dev directory I got the EMC2 configuration
selector used the my-mill checked create desk shortcut then OK it created a
my-mill shortcut icon but it fails to do anything other than a pop up.
If I skip check create desk shortcut and click OK I get
me@CNC:~/emc2-dev$ emc
EMC2 - 2.5.0~pre
Machine configuration directory is '/home/me/emc2/configs/my-mill'
Machine configuration file is 'my-mill.ini'
Starting EMC2...
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
custom.hal:11: parameter or pin 'stepgen.7.position-scale' not found
Shutting down and cleaning up EMC2...
Cleanup done
EMC terminated with an error. You can find more information in the log:
/home/me/emc_debug.txt
and
/home/me/emc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
me@CNC:~/emc2-dev$
Looks like its using files from the preexisting emc2 directory and
did not like the stock tool.tbl contents. Also seems to have used
my custom hal file and had a problem with stepgen.7 which worked
with EMC2 from the live disk. debug.txt contained nothing that I
found useful.
Where did I screw things up this time?
EMC2 - 2.5.0~pre
Starting EMC2...
Cleanup done
and
me@CNC:~/emc2-dev$
found useful.
12 Jan 2011 20:10 #6657
by BigJohnT
You forgot to do a
. ./scripts/emc-environment
in the terminal window before you typed in emc I'd bet.
This sets the environment variables to point to the RIP (run in place) instead of the installed version.
- garymcrobertpdx
13 Jan 2011 00:38 #6658
by garymcrobertpdx
Tried again
me@CNC:~/emc2-dev$ . ./scripts/emc-environment
EMC2 - 2.5.0~pre
Starting EMC2...
File "/home/me/emc2-dev/bin/hal_manualtoolchange", line 57, in <module>
nf.start(app); nf.makecommand(app, "_", _)
File "/home/me/emc2-dev/lib/python/nf.py", line 119, in start
source_lib_tcl(r, "support.tcl")
File "/home/me/emc2-dev/lib/python/nf.py", line 111, in source_lib_tcl
r.tk.call("source", os.path.join(tcl_libdir, f))
KeyboardInterrupt
Cleanup done
and
Hmmm looks the like the same errors. Is some thing in my emc2 dir screwing
things up?
EMC2 - 2.5.0~pre
Starting EMC2...
KeyboardInterrupt
Cleanup done
and
things up?
Time to create page: 0.154 seconds
