RTAI install problems
01 Apr 2011 10:37 #8370 by alexr
RTAI install problems was created by alexr
hello guys
following the procedure from
hart.sourceforge.net/rtai_installation_10_04_woc.html
RTAI metapackage is not in synaptic ONLY the DOCS
here is the commandline in question following the instructions on HART
sudo apt-get install linux-headers-2.6.32-122-rtai linux-image-2.6.32-122-rtai
comes up with
****~/Downloads/rtai$ sudo apt-get install linux-headers-2.6.32-122-rtai linux-image-2.6.32-122-rtai
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package linux-headers-2.6.32-122-rtai
so went to the RTAI website and downloaded latest RTAI tarball ver 3.8.1
using terminal and the ./configure after untarballing
I get this..... (last few lines of ./configure output)
checking for RTAI Kconfig file... ./base/arch/x86_64/defconfig (default)
checking for module installation directory... ${exec_prefix}/modules
checking for Linux source tree...
configure: error: No Linux kernel tree in /usr/src/linux
I did some research and found out on older versions they use a "kernel source package with patches"
so off to synaptic and there is the kernel source with patches. so i downloaded and tried terminal again
so clearly that didnt work
apparently it needs the headers and images installed for the directory tree "according to some forum posts over the net"
leading me back to the 4th to14 lines of this post (back to the beginning)
could it be that the configure file is too narrow and looking for older images/headers/kernel sources i dont have installed?
if so what post ./configure commands should i use to change the kernel tree directory
and why doesnt RTAI show up in synaptic? it use to! i have it installed on another machine from there!!!
should i be contacting some one about this??? can any one else get RTAI?
