Running EMC on 9.10
02 Oct 2009 16:13 - 03 Oct 2009 10:48 #915
by Chewie
Running EMC on 9.10 was created by Chewie
I was trying to move your post to a new thread and botched it up.
Anyway you can not run EMC on 9.10 unless you compile a new something or other for real time and if your not a super linux programmer you will not get there by luck alone. EMC is compiled to run only on the long term support versions of Ubuntu 6.06 and 8.04.
www.linuxcnc.org/
www.linuxcnc.org/docview/html//install_installing_emc2.html
www.linuxcnc.org/
Last edit: 03 Oct 2009 10:48 by BigJohnT.
03 Oct 2009 10:56 #919
by BigJohnT
Replied by BigJohnT on topic Re:Running EMC on 9.10
A little googling of the EMC wiki pages and I found this link for a virtual machine.
www.nongnu.org/qemu/
Normally if your actually controlling a CNC machine you use a stand alone computer just for that. If your just wanting to play with the sims then if you can get a virtural machine to run you can do that or just boot from the live cd and run the sims.
24 Nov 2009 06:06 #1181
by Bari
Replied by Bari on topic Re:Running EMC on 9.10
To build and install EMC2 in Ubuntu 9.04 or 9.10 including the RTAI kernel patches, here's a HOWTO:
neo-technical.wikispaces.com/emc2-ubuntu
Time to create page: 0.119 seconds
