Unfortunately the driver currently only supports cyclic synchronous position control (and I will not have time to look into extending it any time soon).
You'll probably have to configure the drive for cyclic synchronous velocity mode (0x6060 <- 9), and setup the "Sync Manager" in the drive for some PDO mapping that contains target and actual velocity (e.g. 259th PDO: 0x1C12 <- 0x1702, 0x1C13 <- 0x1B02).
See the G5 EtherCAT User's Manual, sections "Sync Manager Communication Objects" and "Process Data Objects".
You cannot do this with the OmrG5 driver (not without doing some coding at least), so unless you want to & can code you'll have to set it up as a "generic" device in the ethercat xml file (type="generic"). I'm not sure on the exact details; better ask in the "Ethercat HAL driver" thread.
Here's an example .xml file that should give some clues at least:
github.com/sittner/linuxcnc-ethercat/blo...ex/ethercat-conf.xml
