new hardware trouble
2 years 1 month ago #311038 by endian
Replied by endian on topic new hardware trouble
I found a sophisticated solution..ethercat master igh(which one we already using) has eoe enabled from default.. it should be set during installation itself .. --enable generic --disable 8190too etc... when u add a --disable eoe... It will newer use them.. read ethercat master igh manual for more details
Let me know
Regards
2 years 1 month ago #311053 by onceloved
Replied by onceloved on topic new hardware trouble
There is also a simpler way to turn off eoe by modifying the parameters in the firmware
2 years 1 month ago #311058 by kworm
Replied by kworm on topic new hardware trouble
Yes, I saw that it could be disabled. Unfortunately I need to use it at least during commissioning because the drives I have can only communicate with the drive commissioning utility with EoE...otherwise CoE has to be disabled and it's like the chicken before the egg problem.
2 years 1 month ago #311088 by endian
For quick check just try something to solve the problem easy.. for long term solution are possibilities here too
I like long term solutions but for troubleshooting u know...
2 years 4 weeks ago - 2 years 4 weeks ago #311247 by kworm
I have found that when sending config pdos to the drive it is successful in LinuxCNC but then lcec dies because it can't map some of the pdos that were just configured.  If you do an "ethercat rescan" then the pdos are shown and LinuxCNC starts just fine.  I'm not sure if this is an linuxcnc-ethercat or etherlab ethercat-master issue.  This may still be some type of interaction with EoE but out of curiosity @endian could you please try seeing if that works for you as well vs disabling EoE?
LinuxCNC was not running during the following commands:
cnc@shaper:~$ ethercat pdos -p 19
SM0: PhysAddr 0x1800, DefaultSize  234, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1a00, DefaultSize  234, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1000, DefaultSize    0, ControlRegister 0x64, Enable 1
  RxPDO 0x1600 ""
    PDO entry 0x6040:00, 16 bit, ""
    PDO entry 0x607a:00, 32 bit, ""
SM3: PhysAddr 0x1100, DefaultSize    0, ControlRegister 0x62, Enable 1
  TxPDO 0x1a00 ""
    PDO entry 0x6041:00, 16 bit, ""
    PDO entry 0x6064:00, 32 bit, ""
cnc@shaper:~$ ethercat rescan
  RxPDO 0x1600 ""
    PDO entry 0x6060:00,  8 bit, ""
    PDO entry 0x60ff:00, 32 bit, ""
  TxPDO 0x1a00 ""
    PDO entry 0x6077:00, 16 bit, ""
    PDO entry 0x6061:00,  8 bit, ""
Last edit: 2 years 4 weeks ago by kworm.
2 years 3 weeks ago #311355 by endian
  RxPDO 0x1600 ""
  TxPDO 0x1a00 ""
  RxPDO 0x1600 ""
  TxPDO 0x1a00 ""
hi,
I do not know what exactly means lcec dies ... but command
sudo systemctl restart ethercat.service
should restart your died ethercat service on your host PC...
I did that what I mention in the posts before... we are not in the situation that we are able to use FAoE, AoE or EoE .. but that time should come soon
My symphtons of not working ethercat service because of EoE on was that... sometimes communication between ethercat slave was turned on(less attemps) and comm was 0 (more attempts) .. but behavior was trully randomable... other slaves on bus was in opmode normally with EoE slave on the bus in same time ...
Time to create page: 0.098 seconds
