User Interfaces
Gmoccapy
Rerunning a tool in qt_dragon_hd
Thank you received: 5
22 Sep 2025 11:40 #335278
by Silverback
I am not sure if this is specific to qt_dragon or not.
However, when I try to rerun a tool because it broke or I need to adjust comps, the process makes me load and set tool length for each tool before it in the nc code.
I'm using versa probe and the Qt auto tool setter routine.
Is there any way to avoid changing each tool before rerunning the desired tool? Often times it's easier and quicker to just repost the single tool path as a separate program to avoid changing all the tools. I'd like to avoid that, if possible.
Moderators: newbynobi, HansU
User Interfaces
Gmoccapy
Time to create page: 0.053 seconds
