- Thank you received: 124
andersal wrote: Hi,
I have problems seeing the workpiece in the lcnc view.
I'm running lcnc 2.7.8 on Debian Wheezy and have downloaded the latest version of NativeCAM from GIT.
I've gone through the setup of ncam and I can start it both stand-alone and embedded.
When running embedded and using the demo config file mill-mm.ini (the metric one), functions seem to be working.
- I can add a workpiece
- I can modify it, etc.
However, I cannot see it.. If i rescale the workpiece I can see the lcnc view changing zoom level but the workpiece is invisible.
Don't know if I can provide any more input for this error or if it's known. Please let me know if I can provide more valuable input.
Anders
You can change probing params default in the 'Preferences/Probing' tabgmouer wrote: I have a couple questions. I have a touchprobe and played around with the probing routines. I understand them fairly well. Is there a parameter somewhere I am not seeing that sets the maximum probe travel before the code faults out? For probing the stock in X and Y I would like a bit more travel so that centering on the stock in the beginning is not as critical.
You can probe a hole or a boss using 'Probe Stock'. Bring the tip of your probe in the center of the hole (above or at the height you want it to be probed) or a boss/cylinder (of course above it), set the mode Inside/Outside, Probe height +/- then run. Safe relative z will be the height it will go up before changing side to probe. You do not have to initially set axes to 0, all values are relative to where it started. The end position will be aligned where you selected for X/Y axes and optionnaly be set to 0.0.gmouer wrote: The other questions is if there are any plans to add more probing routines? Things such as finding the center of a circle pocket or the center of a round boss would be extremely useful.
