- Thank you received: 6
PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
8 years 6 months ago #109058
by DaOne
Create a shortcut and use this as the command...
Replied by DaOne on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
dinkata wrote: please tell how to make launcher in PathPilot 2. for non Tormach machine 5i25+7i77 ?
Sim work ctrl+alt+s .
mate-terminal -x bash -c "~/operator_login"
The following user(s) said Thank You: dinkata
8 years 6 months ago #109059
by dinkata
Replied by dinkata on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
Thanks ,
on startup i choise sim ,
make launcher - ok , work !
How to change from sim to my config 5i25+7i77 ?
my config 5i25+7i77 work in PathPilot 1.9.13 .
8 years 6 months ago #109061
by Stigoe
Replied by Stigoe on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
Hi.
I for one would like a how-to on how to add full functionality to PathPilot. I'm currently converting my benchtop lathe to CNC with PathPilot and I need to be able to compile toggle2nist to be able to add physical buttons. Or do anyone have a working toggle2nist they would share? I'm currently running 2.0.2.
Br,
Stig
Br,
Stig
8 years 6 months ago #109065
Replied by rodw on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
toggle2nist is a standard component.
try typing man toggle2nist and you should get the manual page.
linuxcnc.org/docs/html/man/man9/toggle2nist.9.html
8 years 6 months ago #109068
by Stigoe
In LinuxCNC it's probably correct, in PathPilot it's not. PathPilot comes with a rather crippled version of LinuxCNC, especially PP2.
rodw wrote: toggle2nist is a standard component.
8 years 6 months ago #109103
Well just go to LinuxCNC on github and pull down the comp file and type halcompile --install toggle2nist.comp
Check the docs, you may need to install linuxcnc-dev first.
Time to create page: 0.061 seconds
