plasma control panel
6 years 3 months ago #176619 by phillc54
Replied by phillc54 on topic plasma control panel
I thought it was water to clean the panel out.:silly:
6 years 3 months ago #176627 by rodw
Replied by rodw on topic plasma control panel
tommylight wrote: I wonder, why is there a water/air hose going to the control cabinet ?
Its an inflatable console that doubles as a jumping castle for sure!
6 years 3 months ago #176633 by tommylight
Replied by tommylight on topic plasma control panel
LOL
6 years 3 months ago #176814 by AgentWD40
Replied by AgentWD40 on topic plasma control panel
I've got a quick control panel question. Maybe this belongs in a new, separate thread? ... I just splurged and picked up a big ol' metal nema box to mount my electronics in. It just came in and I poked around with the multimeter. I noticed that the galvanized tray, or mounting plate, does not have continuity with the rest of the metal box. From the factory there is a thin rubber washer and coat of paint that separates the plate's hardware from the box. I would have assumed that I need to ground the metal mounting plate along with the rest of the box. Thoughts?
5 years 8 months ago #198260 by chuben
Replied by chuben on topic plasma control panel
thefabricator03 wrote: I have just finished wiring my new closed loop stepper drives into my control box and added Rods hyper-sensing circuit.
I have attached a updated wiring diagram to this post for anyone that might find it useful.
Attachment not found
Hello, I am new to linux cnc and I have been looking in the forum that thefabricator03 has built a plasma coming from Candcnc products and I am in the same situation. I have a Candcnc system with DC servo motors and Gecko 320X drivers and would like to be able to use them for my new machine. Is there a problem using these products? Thank you
5 years 8 months ago #198261 by rodw
chuben wrote: Hello, I am new to linux cnc and I have been looking in the forum that thefabricator03 has built a plasma coming from Candcnc products and I am in the same situation. I have a Candcnc system with DC servo motors and Gecko 320X drivers and would like to be able to use them for my new machine. Is there a problem using these products? Thank you
The Gecko 320X is quite nonstandard with its error handling.. I found the thread for you.
forum.linuxcnc.org/27-driver-boards/3668...ing-question?start=0
You may be better odd replacing the Gecko drives.. But a solution might also be available as I'm sure others have used them..
Time to create page: 0.515 seconds
