plasma control panel
5 years 7 months ago #204129 by txtrone
Replied by txtrone on topic plasma control panel
rodw wrote: I'm not sure many do add it as its a fairly recent learning. I think his build predated that point.
In this thread, post #134766, he had a 220 ohm in the schematic. By post #148670 there was no resistor. That was the one I was asking about... just to make sure we are talking about the same thing.
5 years 7 months ago #204154 by phillc54
Replied by phillc54 on topic plasma control panel
I think a better idea is to do as PCW suggests and use a 1uf capacitor.
forum.linuxcnc.org/plasmac/40819-arc-ok-...fire?start=50#191678
The following user(s) said Thank You: txtrone
5 years 7 months ago - 5 years 7 months ago #204253 by txtrone
phillc54 wrote: I think a better idea is to do as PCW suggests and use a 1uf capacitor.
I read what PCW had to say... it's a little bit above my pay grade. Is he (I assume it's a he) saying that the 1uf cap would prevent the problem that the OP (and others) were trying to correct with resistors? ... I believe it was the buildup of some sort space dust in the flux capacitor they were trying to blow off.
Last edit: 5 years 7 months ago by txtrone. Reason: Clarification
5 years 7 months ago #204318 by rodw
Replied by rodw on topic plasma control panel
Did someone mention a dusty spaceship?
Yes, if a relay is switching a low current, space dust or oxide can build up on the relay contacts which can result in intermittent/failed operation. The relay manufacturer's specify a minimum current that is sufficient to "burn" off the oxide so it does not form.
5 years 7 months ago #204319 by txtrone
rodw wrote: Did someone mention a dusty spaceship?
That was your cue!
Time to create page: 0.338 seconds
