Difficulties in probing
5 years 2 weeks ago #223017 by tommylight
Replied by tommylight on topic Difficulties in probing
Not sure what is going on but when the float switch trips the torch/probe should stop and move up, not down?????
5 years 2 weeks ago #223019 by snowgoer540
Replied by snowgoer540 on topic Difficulties in probing
It may be easier for us to help you with some video of what’s going on.
It may also be helpful if you posted a backup of your config.
5 years 2 weeks ago #223031 by tommylight
The float switch is not wired properly/not in the input set in hal/not properly connected in hal !
Check the float LED on screen while moving the torch by hand up and down, it should go on and off, i bet it is not.
5 years 2 weeks ago #223036 by Jflesburg
Replied by Jflesburg on topic Difficulties in probing
Yes, the input light on the 7i96 comes on, as does the yellow indicator on screen.
I thought it would be green on screen, but it and the torch on indicators on screen show up yellow when the input or the output is on.
I’ll post a backup of my config when I get home from work.
Thanks for the replies.
5 years 2 weeks ago #223037 by Jflesburg
That’s what I thought. Thanks for confirming. It does transition to a slower speed when the float switch trips. I’ll post a backup config when I get home from work.
Thanks for replying!
5 years 2 weeks ago #223043 by Jflesburg
I have attached a backup of my configuration, so hopefully this will be helpful in finding my problem.
Thanks in advance!
File Name: john_001_v...8.tar.gz
File Size:10.7 KB
Time to create page: 0.308 seconds
