Plasmac Post Processors
  • Moderator
  • Moderator
11 Sep 2025 17:58 #334836 by tommylight
Replied by tommylight on topic Plasmac Post Processors
There are no
N75 M3 $0 S1
in the gcode after the first piece, and no M5 at the end of the cut except for the first cut.
Those must be added by the post processor.
13 Sep 2025 06:17 #334914 by mal136
Replied by mal136 on topic Plasmac Post Processors
IInteresting—I used the Fusion360 post processor from the first page of this thread (forum.linuxcnc.org/plasmac/38438-plasmac...t-processors?start=0). After rereading the PDF, it doesn’t explicitly say so, but I think I need to create separate 2D profiles for each feature I’m cutting. Since the post processor doesn’t generate Z movements, would that mean making individual profiles for all 12+ holes plus the part outline? and i assume plasmaC will control Z when it goes to probe for each cut?  I also tried Inkscape (which I like), but it skips certain splines and rounded corners in my parts. Redesigning everything just to fit Inkscape’s gcode output would be counterproductive.
Thank you so much Tommylight for your reply, i greatly appreciate your help!
  • Moderator
  • Moderator
13 Sep 2025 16:04 - 13 Sep 2025 16:05 #334933 by tommylight
Sorry i can not help with Fusion, i use strictly Inkscape for all plasma machines, just use "prepare for plasma" and then export with the tool chosen as plasma.
Last edit: 13 Sep 2025 16:05 by tommylight.
Time to create page: 0.163 seconds
