Powermill LinuxCNC Post
6 years 6 months ago #163856 by bbsr_5a
Replied by bbsr_5a on topic Powermill LinuxCNC Post
the postprocessor is universel and takes the Axis position out of the Machine POS
it needs a OPT File to produce the lines you like to see this is all graphics and can be manipulated by clicks
like Fixing the Coolend to NON or no output to BlockNumbers
other than standard cams it is a nonTextfile you only can edit it by autodesk Postprocessor tool
and it will only accept things confirm to Righthand Mashine Kinetic Data CDTAD
so from my perspective somewhat easyser for standard user then of Fusion
even the new Feather Cam is a improve in this behavior
What i miss is Powermill brings in a VERY low Level Powershape
only to get its DMT DKG files manipulated in position
you cand make a real Volumen part with no licence
and as we all know almost every Click on autodesk gets its own licening
a real Miss on workflow even on education licencing
That is why i try to stay on INNEO ProE PTC Creo
the Student and educatioon versions are the same and licend for 2years Autodesk 6month/1Y
PTC student files can only be loaded in the same Student version/ SchoolLicence non public
while autodesk is open on this and the Trick to get Companys to work with students for years
then as it is so many files they may need to buy a real licence
PTC did this get separated from the start and opend allmost all exchange formats
Time to create page: 0.043 seconds
