I was having trouble, i realized the second to last command was what messed up so i went back to ~/Desktop/dxf2gcode$ python3 dxf2gcode.py
then it worked. I do have one question though. How do i make a shortcut on desktop so i don't have to type in the command every time?
When I open up the new saved file from dxf2gcode in Linuxcnc it says
Near line 8 of
Tmp/tmpp78t9j/Librycam2.ngc:
Unknown gcode used
Here’s the gcode:
N10 (Generated with: DXF2GCODE, Version: Py3.5.3 PyQt5.7, Date: $Date: Fri Oct 25 20:45:56 2019 +0200 $)
N20 (Created from file: /home/user/Desktop/Unfinished Designs/Librycam.dxf)
N30 (Output format description: G-CODE for LinuxCNC - Plasmac)
N40 (Time: Sun Sep 20 14:42:01 2020)
N50 G20 (Units in inches)
N60 G90 (Absolute programming)
N70 G64 P0.1 G40 G49 G80 G90 G92.1 G94 G67 (preamble)
N80 F#<_hal[plasmac.cut-feed-rate]
N90
(*** LAYER: 0 ***)
N100
(* SHAPE Nr: 1 *)
N110 G0 X 10.0000 Y 18.0000
N120 M3 $0 S1
N130 G1 X 10.0000 Y 8.0000
N140 G1 X 10.0000 Y 18.0000
N150 M5 $0
N160 G0 X 0.0000 Y 0.0000
N170 M2 (Program end)
it seems to be having a problem with this line:
