QtPyVCP Mill Touch V6
7 years 6 months ago #131907 by BigJohnT
Replied by BigJohnT on topic QtPyVCP Mill Touch V6
I've been using Mill Touch V6 on the BP for a short while and I'm liking what I have.
github.com/jethornton/mill_touch_v6
Any feedback is welcome.
JT
7 years 3 months ago #139120 by Ross77
Replied by Ross77 on topic QtPyVCP Mill Touch V6
I have tried to install this but the terminal isn't accepting the git clone command
bash: git: command not found.
The pyqt5.qtsql installed fine.
Running fresh install of Debian stretch
7 years 3 months ago #139122 by BigJohnT
You need to install git.
sudo apt install git
or open the synaptic package manager and install git
I keep forgetting that git is not installed by default...
JT
7 years 3 months ago #139125 by Ross77
Thanks, that's got me a step closer but its still failing to open
Ive copied the config files to the linuxcnc config folder and edited the Ini file but nothing. I even tried opening the ini file in the Mill_touch_v6 folder.
Sorry complete noob
7 years 3 months ago #139130 by BigJohnT
I'm assuming you did the following including the space dot at the end of pip3 install.
git clone https://github.com/jethornton/mill_touch_v6.git cd mill_touch_v6 pip install -e .
in that case lets check if you have /home/username/.local/bin on the path by typing the following in a terminal.
echo $PATH
If that is not on the path then you need to add that by doing the following in a terminal.
printf 'if [ -d $HOME/.local/bin ]; then\n\texport PATH="$HOME/.local/bin:$PATH"\nfi' > .xsessionrc
Then either log out and back in or reboot.
JT
7 years 3 months ago #139170 by BigJohnT
I'm testing my install on a fresh install of Debian 10 and I see I missed a dependency.
I'm creating some documentation for Mill Touch
jethornton.github.io/mill_touch_v6/index.html
JT
Moderators: KCJ, Lcvette
Time to create page: 0.412 seconds
