Probe_Basic Bugs?
1 year 10 months ago #316421 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic Bugs?
I have a XYZB Machine...
1 year 10 months ago #316471 by Lcvette
Replied by Lcvette on topic Probe_Basic Bugs?
yes there is not currently a preconfigured display option setup for xyzb.
however, you could run:
sudo editvcp probe_basic in terminal and make any edits on the apt installed version. if you are on the stable branch the changes will remain, if you are on the develop branch any changes will be overwritten when updates are pushed and you you subsequently run apt update.
1 year 10 months ago - 1 year 10 months ago #316472 by Lcvette
for the issue with second y and z axis being mixed up, this is because the ini axis numbering is off when it adds in the second y axis as axis 2, to fix this, also change the axis number in the properties editor. in your situation it should be set as follows to account for your second Y axis motor:
axisNumber 0 = X
axisNumber 1 = Y
axisNumber 2 = Y2
axisNumber 3 = Z
axisNumber 4 = B
like this below in the images:
Last edit: 1 year 10 months ago by Lcvette.
The following user(s) said Thank You: CNC_ANDI
1 year 10 months ago #316517 by CNC_ANDI
today i have tried... but it dont work... Ref Z will ref my y Axis and REF B will ref my Z Axis... DRO are right but the ref buttons won´t work... when i ref all axis manual (not with ref all) i´ve become an error too when i try to move a axis... the error is joint -1 must be homed but i don´t have joint -1
1 year 10 months ago #316567 by Lcvette
that is a linuxcnc error message being reported. that means your homing sequence may be incorrect or your homing method not correctly specified in the ini. see the docs of the home section for options. if the buttons are not synching up with the axis there is something missing. you will need to have a another look.
1 year 10 months ago #316717 by CNC_ANDI
yes but why? when i try ref all... it works fine...
i think probe basic ref y do only ref my y1 axis and not my y2...
i have 2 homing sensors for y
Moderators: KCJ, Lcvette
Time to create page: 0.227 seconds
