Installing QtVCP
5 years 11 months ago #190828 by Pro_El
Replied by Pro_El on topic Installing QtVCP
I deleted libpyqt5.so like i see in one post, now i have only libpyqt5_py2.so and other 2 with no similar names.
When i start designer -qt=5 nothing in terminal just starts QT- Designer.
What else should i do?
5 years 11 months ago #190830 by cmorley
Replied by cmorley on topic Installing QtVCP
Did you make add a link to the qtvcp_plugin.py to the folder that designer searches?
linuxcnc.org/docs/2.8/html/gui/qtvcp.htm...ude_linuxcnc_widgets
The following user(s) said Thank You: Pro_El
5 years 11 months ago #190832 by Pro_El
Thanks Cris for this help
For the link i do this
sudo ln -s /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/
I am not sure if this is right way to do link??
5 years 11 months ago #190835 by cmorley
I always do the link with the GUI ....
No the second path should be :
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python
or
~/.designer/plugins/python
Did you confirm those are the correct paths? Different systems have slightly different paths.
The following user(s) said Thank You: Pro_El, hottabich
5 years 11 months ago #190836 by Pro_El
Thanks Cris, That was my fault, Widgets now show up
Thanks for Great support
5 years 10 months ago #193235 by tommylight
Replied by tommylight on topic Installing QtVCP
Made this a sticky, tested the script last night on Mint19.3, it works ! :)
The following user(s) said Thank You: phillc54, JohnnyCNC
Time to create page: 0.258 seconds
