QtDragon on Debian Buster, some issues
6 years 1 month ago - 6 years 1 month ago #181292 by keyboard
Thanks to tommylights quick and easy install procedure, I have LINUXCNC - 2.9.0-pre0-2118-g0c8cdaaf1 running on Debian Buster.
Last edit: 6 years 1 month ago by keyboard.
6 years 1 month ago #181306 by cmorley
So looks like that would be buildbot binary.
sudo apt-get update
sudo apt-get upgrade linuxcnc-uspace
should do it
6 years 1 month ago #181358 by keyboard
No luck updating. I get the following :
Hit:1 deb.debian.org/debian buster InRelease
Hit:2 deb.debian.org/debian buster-updates InRelease
Hit:3 security.debian.org/debian-security buster/updates InRelease
Get:4 buildbot.linuxcnc.org buster InRelease [37.8 kB]
Fetched 37.8 kB in 2s (19.8 kB/s)
Reading package lists... Done
W: Skipping acquire of configured file 'buster/binary-amd64/Packages' as repository ' buildbot.linuxcnc.org buster InRelease' does not seem to provide it (sources.list entry misspelt?)
The calibration function works in AXIS, but not in Qtdragon. Also the same with "override limits'. With an axes on the limit switch, and "override limit" checked, one cannot power on the machine.
6 years 1 month ago #181371 by cmorley
You definitely have old code. I don;t know the problem. Andy just released 2.8 so maybe names are changing for buildbot debs.
6 years 1 month ago #181405 by hottabich
I don't quite understand your keyboard problem. Do you have the calibration button inactive?
6 years 1 month ago #181439 by keyboard
Hi hottabich,
Yes, calibration button is inactive and also override limits does not work.
BTW, is that a newer GUI ? I see the Calibration good there.
Time to create page: 0.284 seconds
