Tool touch-off in QTDragon
5 years 10 months ago #193544 by JohnnyCNC
seebaer1976 wrote: How about if you first have to scan all heights with the touch probe and these are then saved and adopted for everything else.
e.g. the height of the tool sensor and the height of the workpiece must be scanned and these heights are then automatically transferred to the offset widgets and are then available for all further routines.
that would save the manual measurement every time and also eliminate any measuring errors or typing errors, since one is already using the touch probe anyway
have been using probe_screen_v2 under axis for a long time and I have no problems with that
Quick manual tool change (Remap M6) described pretty far below on vers.by
verser-git / probe_screen_v2 on github
I was thinking the same kind of thing but I was afraid to ordain a parameter slot for a given purpose. I don't want to tramp on what is being done officially. I will review those docs. I still might try my own solution as a learning experience. The more I look at the code the more familiar it becomes. Next I need to learn the process of contributing and submitting changes. At work I use CVS and TFS source control. I am new to Git.
5 years 10 months ago #193568 by seebaer1976
it is the same for me.
I'm currently looking at how I can use the 2.8 as a productive system and at the same time install the 2.9 in parallel to testing and tinkering.
So the 2.8 and the 2.9 at the same time on one pc.
Unfortunately I haven't found anything yet.
do you happen to know how I can do this?
5 years 10 months ago #193573 by tommylight
seebaer1976 wrote: So the 2.8 and the 2.9 at the same time on one pc.
That is fairly easy to do, install one as normal install and the other as RIP or run in place.
The production version should be installed normally while the development version should be used as RIP as the changes can be verified and tested immediately.
In other words: 2.8 normal install, 2.9 or master as RIP.
The following user(s) said Thank You: seebaer1976
5 years 10 months ago #193616 by seebaer1976
Danke für den Tipp mit RIP, habe es damit finden können
5 years 10 months ago #193632 by tommylight
5 years 9 months ago #195736 by JohnnyCNC
Well, I finally got my M6 Remap to work. Just a recap of my setup. I'm using QTDragon, a 3D probe, and a tool setter albeit a very crude one at the moment but it works for testing this process. I started with the file in WZ-PROBE.ZIP reference in this thread. The changes I made where basically to store the ABS Z value of the probe Z touch-off offest by the length of the probe in #4999. #4999 would be the Z coordinate if the nose of the spindle was sitting on the work. The length of the probe is stored in the .ini file. Then in the remap code I store the value of #5063 in #1890 before probing the tool setter. Then after the probe is complete I call G10 L2 P1 Z[#4999+#1890].
The remap use G59.3 coordinate system, probes the tool and determines its length. Before using this the top of the tool setter needs to be set to zero for G59.3
Now I just need to clean up the code and replace and hard-coded G54s with the appropriate code make this work with any coordinate system. Then figure out anything I did that could be done better. I didn't use anything on the Offsets page in QTDragon but I think I would like to use the "Touch Sensor" to measure the tool and set the work offset for when I am manually milling or running hand written G-Code.
The following user(s) said Thank You: ikkuh
Time to create page: 0.337 seconds
