- Thank you received: 2181
oops, thanksYo have a mistake in the posted Oword file - it still references gmoccapy.blockheight
Would having the enable button on the toolchange dialog work better.
I probably could add that option.
Looking forward to a redesign of the settings page. Would be nice to have pins that are redundant removed. If a pin does a certain job you only need it once. I understand that there will be problems with existing scripts, but isn't it time to do a major overhaul and try to unify the variables?Yes I agree - that was the intention of the button - probably more useful to add it to the toolchange dialog too.
I rethink of the settings page would be very useful. it would be nice to add the remap tool change capability to basic probe too.
AFAIK basic [probe does the same things as versa probe, other then the entries for auto tool probing.
It's actually a bit of a pain as the versa probe widget would need to change based on where it is used. (it's used as a dialog styled probe screen too.)
But its possible.
I'm glad you got it working as you wanted.
There is other work going on to improve integration of auto tool probing remap in qtvcp.
I really want to get rid of any extra HAL pins that users must connect.
I added them for you just so you could get it to work in the mean time.
