[QtDragon] Simple vismach window
4 years 7 months ago #237428 by cmorley
Thanks for the link.
2 years 8 months ago #294680 by Abdulkareem
hello, could you please tell me in which file format do i include this script
2 years 8 months ago #294681 by Abdulkareem
hello, could you please tell me where to write this script
2 years 8 months ago #294693 by Aciera
The vismach model is a python file that creates it's own hal pins and is loaded as a user component from hal.
For Qtvismach it is a bit more complicated than for a regular configuration.
You will need to place your actual vismach file in this folder:
<your_path_here>/lib/python/qtvcp/lib/qt_vismach
Then you also need a folder with a .ui and handle.py file for your vismach simulation here:
<your_path_here>/share/qtvcp/panels
Take a look at one of the preinstalled qtvismach simulations (eg millturn) as a reference.
The following user(s) said Thank You: Abdulkareem
2 years 8 months ago #294883 by cmorley
You shouldn't need to put the vismach file in <your_path_here>/lib/python/qtvcp/lib/qt_vismach.
I've tested a compiled version to confirm but not an installed version.
Also (to be complete) you only need to use an ui/handler file if you want to embed the window or want to add other widgets.
You can load the vismach file directly with python3 - good for testing vismach changes.
