Generating a own Popup
9 months 1 week ago #341662 by DemonClaW
Replied by DemonClaW on topic Generating a own Popup
Im soooo sorry i did miss to Tell you, yeah the original .ui is already touched a bit. The handler is untouched. Ive got trough a Lot of Tutorials and almost everyone copied the Files into their Main Maschine, it Made sence for me to have them all together in one folder so i got with that, too.
In my opinion it would be the easist way to extend the current handler Data so the Rest could stay Like i already got it
9 months 1 week ago #341679 by cmorley
Replied by cmorley on topic Generating a own Popup
ok let's try this:
Since your handler isn't modified, replace it with the one I supplied. It's ok to keep your modified ui file in the config folder.
Of course you still need the INI changes.
If you do want to modify the original handler for other reasons, that can be done, you just need to add most of the code in the handler I supplied.
Just to be complete Qtvcp will use the default handler and ui files unless it find either or both in your config folder.
In the case of the handler file, it's possible to make a special handler file that loads the original and then extend it.
This is nice as if the handler gets updated in linuxcnc, you will get those changes and then the local changes are added on top.
The following user(s) said Thank You: tommylight, DemonClaW
9 months 1 week ago #341712 by DemonClaW
Ive integrated your handler File now into the Main handler. Problem is that the Error Code is exactly the Same as before.
9 months 1 week ago #341713 by cmorley
please post your ui and handler file and the exact error message please.
The following user(s) said Thank You: DemonClaW
9 months 1 week ago - 9 months 1 week ago #341716 by DemonClaW
Yeah for sure these are the files, the error code is already above.
Last edit: 9 months 1 week ago by DemonClaW.
9 months 1 week ago #341718 by cmorley
The ui files are 0 kb for some reason
Time to create page: 0.139 seconds
