- Thank you received: 7
Generating a own Popup
9 months 1 week ago #341726
by DemonClaW
Replied by DemonClaW on topic Generating a own Popup
It worked, i forgot the handler in the /share/ path the Terminallog showed it wanted to load it. After deleting it started with the Button and i can Open the Pop-up too. Thank you very much for your Help and stamina with me
9 months 1 week ago #341727
Replied by cmorley on topic Generating a own Popup
Excellent! Thanks for not giving up.
In this kind of trouble shooting details really matter.
qtdragon is not the same as qtdragon_hd, error messages need to be quoted exactly etc.
When you get everything finished I hope you post a pic of your creation.
The following user(s) said Thank You: tommylight, DemonClaW
9 months 1 week ago #341728
by DemonClaW
Sure I will let you know about the finished Project
9 months 5 days ago #342022
by DemonClaW
Hey Guys,
I was quite busy that week so i didnt get much work into it but here is what i got at this point.
On left down corner you can find a Vakuum button that allows you to switch Clamping variant between a vice or something like that and vacuum clamping. It opens the PopUp on the right side, there you find 4 displays for 4 vacuum plates, your able to switch them on or off depending on how large your workpiece is you can work with 1 or with all 4. The Main Slider down in the middle allows you to set the needed pressure. Every plade is moitored by a single Pressure sensor on a beckhoff EL3124. If the pressure gets lower then the main slider value the system goes immediately in E-Stop mode to provide serios accidents. The main slider may gets removed after i made some experience with the system.
9 months 5 days ago #342032
Replied by tommylight on topic Generating a own Popup
We need a GUI with that industrial design !!!
Looks very ... industrial..
I like it.
I like it.
The following user(s) said Thank You: DemonClaW
9 months 5 days ago #342038
by DemonClaW
I will post some updates when i finished the next steps
Always nice to hear that someone likes the work, Thanks
Time to create page: 0.083 seconds
