My TOS MCV 1000 machining center Retrofit with Siemens 611
2 years 9 months ago - 2 years 9 months ago #291246 by radom
LED green –Ext. enable signal not available (terminal 63 and/or 64 missing
you want yellow led to be present
terminal 9 is your 24V supply, you don't need anything else
just connect terminal 9 to 63,64,65,663
I don't know if you have a brake on Z axis motor, then you need to check where is it connected before applying voltage to axis 56/14
Last edit: 2 years 9 months ago by radom.
2 years 9 months ago #291343 by santy
ok . i will test this now. i hope i haven't fucked up by supplying 24v to 9 in the first place. first will check the brake thing on the Z but i think it does have something
thank you, will update.
2 years 9 months ago #291554 by santy
Well…. No change in color light yet. Might be something disabling the drives.
what about AS1 or AS2? any ideas on what  do they do?
2 years 9 months ago - 2 years 9 months ago #291605 by radom
as far as I remember AS1 is a relay
assets.euautomation.com/uploads/parts/da...6sn11231aa000da1.pdf
on the left side I see you took a wire from terminal 64 but what about terminal 63? I can't tell from the photo,
terminal 63 is third pin higher from the 64
2 years 9 months ago #291655 by santy
Exactly, all you have said, makes a lot of sense. I have checked the manual and it makes sense too. I didn’t have 64 connected
When I have all others connected, I have a green light. The moment I connect 64, the green light disappears and no yellow light :(
2 years 9 months ago - 2 years 9 months ago #291744 by radom
sorry I had to look it up how I got my simodrive wired and I think I forgot about terminal 48 on the left side it also need to be connected to terminal 9,
there is a flowchart for start-up in the pdf I linked earlier
Time to create page: 0.309 seconds
