- Thank you received: 19
DaBit wrote: Skunkworks was faster; I was just going to give the same answer.
This seems to be one of those typical 'welcome to CAM-software' issues. If the new TP is good enough in optimizing line-line transitions, there is virtually no problem anymore since everything can be approximated using line segments. Nice solution? No. Practical? Yes.
skunkworks wrote: exactly.. And in the future there may be a solution for other segment transitions..
To recap - so far the readahead works with
line-line segments
tangent line-arc segmetns
tangent arc-arc segments
Rick G wrote: The new TP runs the arcs and the circle at the same steady speed, so the first portion runs smoother and faster. This speed is somewhat slower than the current TP did the full circle.
Rick G wrote: Where the current TP blends on exiting the circle to the straight the new TP appears not to and prepares for a stop even thought there is a extra lead out move.
