TCP 5-axis kinematics
5 years 3 months ago #214512 by Aciera
Replied by Aciera on topic TCP 5-axis kinematics
Ah, as Andy suggested, in this case it would be easier to try the buildbot installation method!
I don't use this much so I don't know if I have everything covered but this should get you started:
So first you would install the official linuxcnc ISO with the 2.8 version :
www.linuxcnc.org/iso/linuxcnc-2.8.0-buster.iso
Then update to master
Add the key : This is from here: buildbot.linuxcnc.org/
add the buildbot archive signing key to your apt keychain by running this command in a terminal:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
Then add the packages to the repository: (This is from linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html )
Click on Applications Menu, then System, then Synaptic Package Manager.
In Synaptic, click on the Settings menu, then click Repositories to open the Software Sources window.
In the Software Sources window, select the Other Software tab.
Delete or un-check all the old linuxcnc.org entries (leave all non-linuxcnc.org lines as they are).
Click the Add button and add a new apt line:
deb http://buildbot.linuxcnc.org/ buster master-rtpreempt deb-src http://buildbot.linuxcnc.org/ buster master-rtpreempt
(These can be found here: buildbot.linuxcnc.org/ )
5 years 3 months ago #214513 by JackRay
Replied by JackRay on topic TCP 5-axis kinematics
Thanks, I'll try this right away and report back to you.
Can test on a Linux mint distribution or is the distribution included in the .iso file that you communicated to me?
5 years 3 months ago - 5 years 3 months ago #214514 by Aciera
You can also use the mint distro.
[edit]
actually I'm not sure if the repo for the mint distro need to be different (stretch?)
[edit2]
Note that the use of the official ISO seems now the recomended method:
forum.linuxcnc.org/9-installing-linuxcnc...ation?start=0#137159
Last edit: 5 years 3 months ago by Aciera.
5 years 3 months ago #214540 by tommylight
Replied by tommylight on topic TCP 5-axis kinematics
Stretch is not built anymore, so buster is the one to use for Mint 19.x.
There is a quick and updated tutorial for Mint 19.x on the "installing LinuxCNC" section of the forum, it is pinned at the top so easy to find.
5 years 3 months ago #214568 by JackRay
I installed "Linuxcnc 2.8.0 buster.iso", nothing works, I can't even do an "Update my system". I would like to make a screenshot for you, I can't even find an application to paste my image ...
5 years 3 months ago - 5 years 3 months ago #214572 by Aciera
I'm afraid this doesn't really tell me anything. (ie does it not boot, or does it crash, or can't you find your way around XFCE)
The ISO is fairly bare bones and light. But you should be able to connect to the internet, open the software manager and run linuxcnc.
[edit]
The changeover from LinuxMint might be a little bumpy but pretty much anything you might think your missing can be installed, you can even change the desktop manager to cinnamon as in LinuxMint.
Time to create page: 0.278 seconds
