another noob trying to tune the servo
8 years 1 month ago - 8 years 1 month ago #117761 by PCW
Are you sure you have disabled all power management in the BIOS?
Disable Cstates >1
also disable legacy USB
2 MS delays really suggest power management issues
It may also be a bad hard drive (do you see error messages in the kernel log?)
Last edit: 8 years 1 month ago by PCW.
8 years 1 month ago #117763 by Psykhon
latency run result:
RTAI Testsuite - USER latency (all data in nanoseconds)
2018/09/19 17:43:21
RTH| lat min| ovl min| lat avg| lat max| ovl max| overruns
RTD| -1456| -1456| -1435| 3192| 3192| 0
RTD| -1456| -1456| -1234| 1968684| 1968684| 19
RTD| -1456| -1456| -1434| -1039| 1968684| 19
RTD| -1456| -1456| -1434| -735| 1968684| 19
RTD| -1456| -1456| -1237| 1963638| 1968684| 38
RTD| -1456| -1456| -1434| 3530| 1968684| 38
RTD| -1456| -1456| -1234| 1958281| 1968684| 57
RTD| -1456| -1456| -1436| -780| 1968684| 57
RTD| -1456| -1456| -1236| 1959735| 1968684| 76
RTD| -1456| -1456| -1437| -1045| 1968684| 76
RTD| -1456| -1456| -1435| -777| 1968684| 76
RTD| -1456| -1456| -1236| 1956089| 1968684| 95
RTD| -1455| -1456| -1433| 2611| 1968684| 95
RTD| -1456| -1456| -1238| 1952266| 1968684| 114
RTD| -1456| -1456| -1436| -735| 1968684| 114
RTD| -1456| -1456| -1236| 1946340| 1968684| 133
RTD| -1456| -1456| -1435| -1076| 1968684| 133
RTD| -1456| -1456| -1434| -751| 1968684| 133
RTD| -1456| -1456| -1236| 1947316| 1968684| 152
RTD| -1456| -1456| -1437| -1056| 1968684| 152
RTD| -1456| -1456| -1238| 1938992| 1968684| 171
2018/09/19 17:43:41
RTD| -1456| -1456| -1433| -793| 1968684| 171
RTD| -1455| -1456| -1237| 1934986| 1968684| 190
RTD| -1462| -1462| -1438| 2602| 1968684| 190
^CRTD| -1462| -1462| -1438| 2602| 1968684| 190
8 years 1 month ago - 8 years 1 month ago #117764 by Psykhon
Also tried disabling lan, usb, ide busmaster, everything non essential, same latencys
Killing Xserver, same
Init 1, also same results
Is there a better way to pinpoint where the latency may come from?
the Latency FAQ post says that the SMI latency spikes are regularly between 32-64 secconds, but I have them in 1-3 seccond period
Last edit: 8 years 1 month ago by Psykhon.
8 years 1 month ago - 8 years 1 month ago #117765 by Psykhon
Disabled CStates, legacy and also tried booting from a pen drive, no difference
Hard drive is a 32gb SSD
8 years 1 month ago #117768 by tommylight
Can you download and boot Linux Mint Mate version, in the preferences menu there is an entry named "disks", open that and do a benchmark of the said SSD, check that the read and write lines are linear with no spikes, if there are huge spikes it points to serial ata problems on the mainboard. Had a fair share of those.
8 years 1 month ago #117769 by Psykhon
It was the SMI!, after unsuccessfully tried to recompile the smi module to accept the ich10 chipset, just downloaded the smictrl tool and this was the result
## RTAI latency calibration tool ##
# period = 100000 (ns)
# average time = 1 (s)
# use the FPU
# start the timer
# timer_mode is oneshot
2018/09/19 19:23:48
RTD| -1457| -1457| -1436| -878| -878| 0
RTD| -1456| -1457| -1431| -667| -667| 0
RTD| -1456| -1457| -1430| 2759| 2759| 0
RTD| -1455| -1457| -1435| -916| 2759| 0
RTD| -1456| -1457| -1438| -997| 2759| 0
RTD| -1456| -1457| -1431| 3546| 3546| 0
RTD| -1456| -1457| -1435| -687| 3546| 0
RTD| -1456| -1457| -1436| 2710| 3546| 0
RTD| -1456| -1457| -1433| -1021| 3546| 0
RTD| -1456| -1457| -1430| -645| 3546| 0
RTD| -1458| -1458| -1437| -682| 3546| 0
RTD| -1456| -1458| -1437| -782| 3546| 0
RTD| -1456| -1458| -1437| -897| 3546| 0
RTD| -1456| -1458| -1429| -642| 3546| 0
RTD| -1456| -1458| -1435| -902| 3546| 0
RTD| -1456| -1458| -1433| -1005| 3546| 0
RTD| -1456| -1458| -1434| -680| 3546| 0
RTD| -1456| -1458| -1432| -662| 3546| 0
RTD| -1456| -1458| -1437| 3554| 3554| 0
^CRTD| -1456| -1458| -1437| 3554| 3554| 0
also added this simple script to init.d:
#!/bin/sh
### BEGIN INIT INFO
# Provides: blabla
# Required-Start: $syslog
# Required-Stop: $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: blabla
# Description:
### END INIT INFO
smictrl -s 0
Time to create page: 0.145 seconds
