failure Huanyang VFD HY01D523B
4 years 7 months ago #237924 by andypugh
I don't see a parallel port helping here. Unless you are hoping that a PC swap will fix the problem (And I see no reason to expect it to).
Why not switch ti running the VFD with analogue voltage control?
I am wondering if you have one of the fake HY VFDs?
You could draw a matrix of all the possible VFD settings (including the jumper position and comms wire polarity) and all the hy_vfd settings and just work through them methodically. You can cycle through the hy_vfd settings pretty quickly using the halrun command-line.
Of course, this might just be a long-winded way to prove that it doesn't work.
4 years 7 months ago #237931 by Manu663
Thanks andy, I'll take your advice and start this long term check.
One thing comes to mind... wouldn't the wild swapping of the hard drive I did compromise an execution address?
Is it worth trying with a LinuxCNC live CD first ?
4 years 7 months ago #237933 by andypugh
I really don't think so, the hy_vfd component runs in user space. If it runs at all, it should work. Running it from the halrun command line takes most of LinuxCNC out of the picture.
4 years 7 months ago #237940 by Manu663
Great so I'll try the complete check up then.
I'll come back here to expose any progress.
Time to create page: 0.235 seconds
