I have a Bosch that can do that easily, it does 63NM!
I can't imagine trying to mix in 20 pounds of steel fibers in a bucket with a cordless drill.
I've got two questions:No 'official' resources I've found (like peer-reviewed journal studies) specifically on DIY machine building.
There has been discussion of CSA properties, as well as a couple of build logs of moderately informative content, on CNCZone. The epoxy-granite and DIY sub-forums are littered with lots of back-and-forth debates, but there were a few threads in the past couple of years which included discussion of CSA concrete and attempts to quantify improvements in stiffness.
A number of concrete-only, or concrete-filled machines have been built by people over the years - there are even some YT vids available. I think the fundamental problem with using concrete is that Portland-cement based concrete shrinks and cracks. Using it to fill structures doesn't work well (far as I know) as the shrinkage decouples it from the outer structure and it just becomes a weight without adding any strength or stiffness to the assembly. Even if cast around internal steel reinforcement it still cracks and shrinks. Weight is certainly good, but it tends to be a by-product of a massive structure rather than the end goal.
Epoxy doesn't appreciably shrink when it cures, allowing it to stay in contact with the structure (or remain stable if it is the entire structure). But epoxy isn't stiff - compared to metals, ceramics, or rocks. So you add stiff fillers (which also reduce the cost) and, in theory, you get an improved bulk stiffness for the whole casting. Problem is that without some trial and error and fairly tight control of the mix and placement, you will wind up with a heavy, but not extremely stiff casting. Plus casting in really thick sections is a challenge without fairly specialized epoxy (i.e. overheating).
The deal with CSA cement is that it doesn't shrink like Portland cement. It can also achieve extremely high compressive strengths very rapidly. So can Portland-based UHPC, but those take rather a long time to achieve the high strengths and they still have the shrinkage problem.
CSA isn't extremely stiff (compared to steel), but adding stiff fibers to it improves things dramatically. Fibers are typically added to UHPC for crack control, but a side benefit is that steel or basalt fibers increase the average stiffness... something desirable for a machine tool frame.
So the 'ideal' frame uses a high tensile strength outer skin, and a high compression strength internal filler... and design the geometry so that the skin is in tension and the core is in compression. Then make sure the connection between the skin and core is intimate and will not dis-bond (or is mechanically coupled). Make sure both the filler and skin are very stiff and you've got a solid assembly.
