- Thank you received: 4
Oh, that's very valid argument. I haven't considered that this will quite a lot of surface and possibly require some significant force. Definitely won't go that route.It may work, but I wouldn't trust it to remain flat over that distance for multiple uses over a period of time.
Box levels are made from aluminum extrusions, and extrusions have residual stresses from the manufacturing process. Machining two parallel faces helps eliminate some of the compression forces remaining in the outer skin, but I'd be afraid of thermal movement while handling it or using it on a hot day vs. a cold evening. Plus the fact that you may need some force to impress a flat surface in to some epoxy and the aluminum would flex more than a steel, cast iron, or granite device.
Good score!
Not really.
